Author Topic: Running lean  (Read 1302 times)
Offline Johnny5
    • CB350F build thread
Running lean
« on: August 18, 2009, 06:20:08 PM »
Still fighting with my friend's 750K4. Spark plugs 2-4 are a nice light tan. Cylinder 1 plug, whiter than I like and the pipe was beginning to blue around the exhaust collar area. And when I rev the engine, the revs hang a little before settling down. I guessed it was an air leak around the boots, so I sprayed WD-40 around the carb boots on the engine side and also around the airbox side. No change at all in the rpms. Can there still be a leak even though this test is negative? Or should I be looking for something else?
The carbs have been cleaned and floats adjusted, throttle cables lubed and are not binding. Even took the carbs off a second time to double check it all.
It's too late to work on it tonight, so tomorrow Im going to grab a couple cheap hose clamps to see if I can squeeze the carb boots a little tighter on cylinder 1, just to see if it clears up the lean condition.
Im open to any other thoughts on what to look for.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline 1timduke
  • '75 CB550
Re: Running lean
« Reply #1 on: August 18, 2009, 08:56:31 PM »
Is this happening at idle only, or have you done a plug chop for the plug deposits?   Um, leaky boots...plugged idle jet...definitely need a carb sync...ummm....maybe an obstruction in the T fitting between #1 and #2 carbs... ummm...pinched fuel line...ummm...exhaust leak on #1 pipe...what does #3 look like?
-Tim
The only thing I miss about the South is Waffle House!
Offline Johnny5
Re: Running lean
« Reply #2 on: August 19, 2009, 04:17:47 AM »
Carbs were vacuum synced and all the other maintenance adjustments. It started to run really warm because of the lean cylinder.
1971 CB350
1973 CB350F
Offline 1timduke
  • '75 CB550
Re: Running lean
« Reply #3 on: August 20, 2009, 11:36:58 AM »
Ummm...how about the screw in the manifold where you put the sync gauge, did you put it back it back in?   I only ask because I did this :P :P :P
-Tim
