Author Topic: #2 not firing  (Read 943 times)
Offline milogreen
#2 not firing
« on: August 19, 2009, 10:46:38 AM »
In the process of syncing my carbs I discovered that # 2 cyclinder wasnt firing. I checked the bowl for gas ( plently) and  checked the plug for spark by pulling the plug and hooking it up to the plug wire and holding against  the engine (seems like good spark, Shocking experience) I even tried switching plugs still no heat from # 2 pipe. I checked the tappets as well.  My guess is a bad coil wire but I did get good spark when I held the plug against the block. Any ideas? ???
Offline johnny_from_bel
  • Member #158
Re: #2 not firing
« Reply #1 on: August 19, 2009, 10:52:04 AM »
First measure the compression just to make shure.
To find out if it is a fuel or igition question. Take the airbox off and run the engine.
Spray some starter fluid (like startpilot) or WD40 in carburetor of #2.  If it caches on, its a fuel problem if not it is ignition.
Offline Mdub
  • Xspurt
Re: #2 not firing
« Reply #2 on: August 19, 2009, 12:20:37 PM »
I recently had that problem and it f'd with me for half a season.
Turned out to be a brass float with pinholes in it, allowing it to sloooooooooooooooooowly fill with gas.
Looks like plenty of fuel in the bowl and there is, but, with a half submerged float,
the float needle/metering mechanism doesn't work so well.
Remove the float (if it's brass) and shake it to see if there is any gas in it. I've seen plastic ones 'water (gas) log' as well.
A quick check is to swap floats around and see if the problem follows the float.
Good luck,
Mike
X= an unknown quantity
Spurt= a drip under pressure!
Offline Johnie
Re: #2 not firing
« Reply #3 on: August 19, 2009, 12:53:40 PM »
Run and check the plug to see if unburned gas on it.  Just had the same deal and it was a plugged slow jet.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Brian G
Re: #2 not firing
« Reply #4 on: August 19, 2009, 01:18:06 PM »
An easier way might be to swap the plug wires between 2 & 3 (the plugs on two and three spark at the same time - waste spark) and see if the problem moves to #3 cylinder.
Hth,
Brian
1975 Honda CB400F
1978 Honda CB550K
1979 Honda CBX
1969 BSA Rocket 3
1976 Kawasaki KH400
2008 Kawasaki C14 Concours
Offline milogreen
Re: #2 not firing
« Reply #5 on: August 19, 2009, 06:29:43 PM »
I dunno how it happened but it turned out to be a bad spark plug.
Offline Brian G
Re: #2 not firing
« Reply #6 on: August 20, 2009, 05:36:01 AM »
Another mystery solved  :D
Thanks for the update. Always nice to know when and how a problem is fixed!
1975 Honda CB400F
1978 Honda CB550K
1979 Honda CBX
1969 BSA Rocket 3
1976 Kawasaki KH400
Offline Mdub
  • Xspurt
Re: #2 not firing
« Reply #7 on: August 20, 2009, 10:16:17 AM »
+1
