Author Topic: Rear axle spacer order?  (Read 2131 times)
damn_yankee
« on: November 28, 2005, 05:23:12 PM »
Hi again,
Just got new Dunlop D404s for the bike. I assembled the rear tire and spacers back in the order (I thought, doh!) it was disassembled. The chain seems to be offset a small amount and is binding a little bit.
Can anyone verify if my spacers are correct? The clearances appear fine on the bike so perhaps I just need to adjust some more. I just want to be sure...
Thanks,
Jeff
« Last Edit: November 28, 2005, 05:26:55 PM by damn_yankee »
Re: Rear axle spacer order?
« Reply #1 on: November 28, 2005, 05:51:42 PM »
And, we would know which bike this is because.....
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: November 28, 2005, 05:54:20 PM »
That left side doesn't look anything like the spacing on my 750 K0. What bike/model?
damn_yankee
« Reply #3 on: November 28, 2005, 06:06:54 PM »
Sorry, CB750 K8
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: November 28, 2005, 07:15:33 PM »
Here's a K model diagram from a K8/F3 manual. Hope it helps.
damn_yankee
« Reply #5 on: November 28, 2005, 07:20:12 PM »
Thanks Bob,
I have that page from the manual but it's not too clear on the spacer locations...
Any K8 people out there that can check their rear axles ?
Thanks
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6 on: November 28, 2005, 08:15:58 PM »
I hope this helps. I crashed my stupid computer 4 times trying to get my $24.00 camera to download the picts I took of my bike.
P.S. It's blowing about 60knts and cold out there!
Big one goes on the right little one on the left.
Your spacers look nothing like the ones on my 78K8
See below...does it look cold? BRRRRRRR
damn_yankee
« Reply #7 on: November 28, 2005, 09:31:15 PM »
Seaweb,
thanks for taking the time to post pictures. The width of the right spacer looks about the same as mine.
I'll leave it as is unless someone shows me a reason it's not correct.
Thanks again,
Jeff
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #8 on: November 28, 2005, 10:15:39 PM »
"I'll leave it as is "? ?????
I thought you said.......... "The chain seems to be offset a small amount and is binding a little bit. "
Your left one looks to be to wide, by about 1/2 inch?
Good luck ;D
Offline dusterdude
« Reply #9 on: November 29, 2005, 06:13:35 AM »
the right is the same one my k1 has,i cant remember what the left looks like so im no help there
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline cb(r)
« Reply #10 on: November 29, 2005, 06:56:14 AM »
the spacers looks right.  I have a question though.  did you make sure the rim and tire are straight with the bike?
this might be an optical illusiong but it looks like the right side of the axle is a liitle bit forward towards the engine?
definitly double check the alignment of you axle with the witness marks on the swingarm.
hope that cures the prob
damn_yankee
« Reply #11 on: November 29, 2005, 07:56:45 AM »
OK thanks cb and dusterdude.
I'll have to check the adjustment but it sounds like the spacers are in the correct place.
Thanks,
Jeff
Offline dusterdude
« Reply #12 on: November 29, 2005, 08:16:38 AM »
yea,now that ive eyeballed your pic at bit more,it appears your spacing is correct.good luck
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
