Author Topic: Question about polishing the engine  (Read 778 times)
Offline callbr549
« on: August 19, 2009, 06:09:06 PM »
Here's a question from a rank amateur, novice motorcycle owner. I want to polish some of the pieces of my CB750 engine case (if thats the right term) -- transmission cover, clutch cover, etc.  My questions are:
Are there any bits or pieces that I might remove that will damage gaskets that I should have on hand before removing the piece? Are gaskets hard to find or can they be fabricated from sheet material using the old gasket as a patter?
I'm assuming that some pieces,the transmission cover for instance, I will need to drain engine oil before removing or risk a puddle of oil on the garage floor.
Offline razor02097
  • Not a fool, just an
  • Yes its a Honda You got an F'in problem with that?
Re: Question about polishing the engine
« Reply #1 on: August 19, 2009, 06:11:19 PM »
No worries gaskets are readily available for these old beasts
Project Rina
That is an inconceivably egregious transgression against my rudimentary concordance of socially shunned individuals.
Offline kghost
« Reply #2 on: August 19, 2009, 06:21:07 PM »
750 is a dry sump engine.
There will be some oil behind the covers.
Just shouldn't be 3 quarts...it should be in the tank.
While you have the covers off...replace the seals in the covers...
They never stand up well to age and high speed buffers....
Stranger in a strange land
Online Johnie
« Reply #3 on: August 19, 2009, 06:32:03 PM »
Plus there is a lot of info on this board about polishing those covers.  Just do a search and have at it...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
