Author Topic: Will a 1981 650 'nighthawk' overhead and carb fit my 78 cb550k?  (Read 2653 times)
Offline Tretnine
  • Prove it,
  • Figuring it out, one expletive at a time.
    • http://www.behindbarsmotorcycle.com/
All I really want to know is if the 1981 650 'nighthawk' will fit my 78 550. I know you can use 650 overheads from early 80s models, but I'm not so sure what the 'nighthawk' was in that time frame. I thought actual nighthawks started in 82.
2009 Kawasaki Concours, 1978 cb550k, 2006 BMW F650GS
Member of the AMA
Re: Will a 1981 650 'nighthawk' overhead and carb fit my 78 cb550k?
« Reply #1 on: August 19, 2009, 07:48:16 PM »
sohc maybe
dohc doubt it
what is an overhaed?
Offline Tretnine
  • Prove it,
« Reply #2 on: August 20, 2009, 02:12:52 PM »
Sorry, the cylinder head, cam, and cam chain. I'm looking into the 650 top end on a 550k mod. I may also have a line on a 79, but I want to know what actually works. Also curious about what carburetors would work on which bikes.
Member of the AMA
Offline cb650
« Reply #3 on: August 20, 2009, 04:05:08 PM »
Nitehawk came out in 82.  What does the frame say?  They will also have the CV carbs which wont "bolt on" to the 550 like the 79/80 meck carbs will.
Nitehawks also had one big rectangular gauge housing.
Offline Tretnine
  • Prove it,
« Reply #4 on: August 20, 2009, 05:02:52 PM »
so if I wind up with nighthawk top end I would have to switch to fruity square gauges to have the tach read correctly and the carburetors wouldn't work. They won't 'bolt on' but they could be jimmied? I'm hoping to get a 79 motor and carb rack, but we'll see...
Member of the AMA
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #5 on: August 20, 2009, 05:28:44 PM »
If you use a 650 head, you'll need to use 650 pistons. Asked this of Paulages a while back. Running 550 pistons in a 650 head will make compression VERY low.
Also, it isn't a direct bolt on.
You can use the 650 cam (assuming it's a sohc 650), but you'll have to attach the 550's cam gear and use the 550 cam chain.
No.
Offline Slippery
« Reply #6 on: August 20, 2009, 05:50:30 PM »
'83-'85 DOHCs did, but '82s had the standard round clocks.
Offline jeepster
« Reply #7 on: August 20, 2009, 06:30:14 PM »
Indeed:
"An ounce of prevention is worth more if you break it up into nickel bags."
Offline Tretnine
  • Prove it,
« Reply #8 on: August 21, 2009, 05:44:56 AM »
Tell me more of this. Do I need to overbore the engine or is the difference in stroke length? Why is compression so low with 550 pistons?
Member of the AMA
Offline cb650
« Reply #9 on: August 21, 2009, 06:21:42 AM »
Yes the "gauges" them selves are round but take them off and the whole rectangular (mostly) comes off as one piece.  Not like the round individual of the other 650's.
I only mentioned that as a way for him to ID the bike he had.
And yes if you use a 650 cam you will need a 650 tack. Off any sohc650.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #10 on: August 21, 2009, 06:41:33 AM »
You'd need to bore. The combustion chamber of the head of the 650 is larger. The 550 pistons are near flat while with 650 pistons are domed.
No.
Offline Tretnine
  • Prove it,
« Reply #11 on: August 21, 2009, 01:47:56 PM »
Interesting. After I first read about this mod I thought it'd be simpler than it is. There are really a lot of things needed to make this work right. At any rate, it still seems like something I'd be interested in, provided I could get the parts without paying too much. I might have a line on an engine, but how much is an overbore like this? Does anyone have a good referral for somewhere to get machining done in central VA?
Member of the AMA
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #12 on: August 21, 2009, 01:53:20 PM »
650 bore and stroke : 59.8 x 55.8 mm
550 bore and stroke : 58.5 x 50.6 mm
Not a huge overbore.
Most people just slap on the 650 cam to the 550 for a mellow little boost.
The 650 head, from what I've seen, looks vastly superior in terms of low and design, though, so I think It would be a good mod.
According to Paulages, there some fairly minor machining that would need to be dont to get the 650 head to fit on the 550 jugs, though.
No.
Offline Slippery
« Reply #13 on: August 26, 2009, 12:30:09 AM »
Ah, outer gauges with the warning lamps between, in the same panel. Gotcha.
