Author Topic: Best source for a CB500 head gasket?  (Read 5739 times)
Offline zoo mob
« on: August 20, 2009, 12:43:58 PM »
Just bought a 72 CB500 motor to swap into a 74 550, and it look like the head gasket has a leak, figured now is the time to replace it, looked at my local Honda dealer's fiche, and the gasket alone is $56.00, does this seem high? Anything else I should replace while in there? And any idea on a cheaper source or aftermarket gasket that is just as good?
Thanks
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
Re: Best source for a CB500 head gasket?
« Reply #1 on: August 20, 2009, 01:18:47 PM »
the base gasket might be displaced when removing the head, so i'd consider replacing that.  for sure i'd also replace pucks and all "o"rings.  i'd re-torque the head bolts after running for a bit.
bobp
searching for a dr350se
Offline neudl
« Reply #2 on: August 20, 2009, 01:23:23 PM »
I used an Athena top-end gasket set - about $100 - its the same set as for the CB550.  I have had no leaks over the last couple of years since replacing all the top end gaskets.  As long as you have the top end apart, I would replace all of the top end gaskets, o-rings, and pucks (which will come with the set).  Also may be a good time to replace any other worn top-end parts - cam chain, guide, etc.  When I replaced the top-end gaskets I also had the head machined smooth, and replaced all of the pistons and rings.  CB500 rings were hard to find, and the set I ordered spent almost two months lost in transit.
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #3 on: August 20, 2009, 03:07:15 PM »
Honda OEM (via Honda Direct Line):
6 - GASKET, CYL HD 12251-374-306  (replaces 12251-323-005)  -  $54.37
http://www.hdlparts.com/fiche_section_detail.asp?section=122830&category=MOTORCYCLES&make=HONDA&year=1972&fveh=2936
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
Offline turboguzzi
« Reply #4 on: August 20, 2009, 03:36:25 PM »
david silver sells them for 25 british pounds  but who says you need one?
 if its the typical CB500 oil leak at the head joint (and 99% it is) then those are the small rubber o-rings that have dried, not the main gasket.  there are forum threads that offer advice on that problem
pulling the head AND the cyl block AND changing rings as some people recommend here is WAYYYY over the top IMHO. You can get the head out without disturbing the bottom gasket and even if you do, that gasket is not so bound to leak anyway.
TG
