Author Topic: Replacement Coils  (Read 2610 times)
Hyseman
Replacement Coils
« on: November 29, 2005, 09:41:26 AM »
I have a 73 CB750 and need to replace the coil because of a broken plug wire. I found a place that will sell me 1 of 2 types.
Type 1 has the plug wires as part of the coil.
Type 2 has the plug wires that are seperate.
Other than ease of replacing wires is there any other advantage to one  or the other?
damn_yankee
Re: Replacement Coils
« Reply #1 on: November 29, 2005, 10:09:53 AM »
I saw somewhere on this site there is a way to replace damaged wires by carefully drilling out the old wire in the coil and inserting a new plug wire. Do a search.
If the coils are still good, spark plug wire is a lot cheaper.
Offline dusterdude
« Reply #2 on: November 29, 2005, 10:36:32 AM »
either will work but,the type with the removeable wire might be a 3 ohm coil,our stock coils are 5 ohm.i have 3 ohm coils on my bike now with no ill effects,some say you see premature wear of the points with this setup.like i said so far thats not an issue.if the molded coil is in good shape you might just want to go that way.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline cb(r)
« Reply #3 on: November 29, 2005, 11:00:27 AM »
I had a 92 yamaha fzr that I had a similar problem.   I milled into the coil and inserted new and better wires.  It  just had prong to fix my wires to. not a threaded prong like I thought.  it fired better though.  matter of fact I have the coil off my cb 550 with two broken wires.  I might just cut into them if I have time today.  I will keep you updated.  I have no camera but once I do I will send pics.
Offline cb(r)
« Reply #4 on: November 29, 2005, 12:16:40 PM »
warning do not cut into coil from a 74 cb 550 wires are soldered in and very difficult to clean replace and resolder.
check out this site for coils   http://www.z1enterprises.com/
If it were me I would go with the coil pack that has the correct ohm rating as your bike  and changeable wires.
Hyseman
« Reply #5 on: November 29, 2005, 12:55:01 PM »
Can the boots be changed if the coil is good?
eldar
« Reply #6 on: November 29, 2005, 02:09:06 PM »
Boots only help if the wire is good.
You can go to www.partsnmore.com and get new coils for a 1979 cb750 that uses replaceable wires. They are $26. Unless you have a good electronic ign, these coils are absolutely fine. So for about $40 each, you could have new coils, wires, and boots which will outperform the old original coils anyways.
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #7 on: November 29, 2005, 03:29:04 PM »
Partsnmore also sells the molded in wire 5 ohm coils for $30 US       Part # 17-6822
https://www.partsnmore.com/cat_index.php?model=cb750_sohc&category=electrical
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Hyseman
« Reply #8 on: November 30, 2005, 06:58:50 AM »
What year coils can I use on my 73 CB750?
What other parts are interchangeable?
Offline dusterdude
« Reply #9 on: November 30, 2005, 07:02:33 AM »
you can pretty much use any jap coil i think,i have yamaha coils on my bike
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #10 on: November 30, 2005, 07:05:15 AM »
Some folk here use VFR coils or DOHC 750/900 coils.
You may have to fab a mounting bracket.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Hyseman
« Reply #11 on: November 30, 2005, 07:28:29 AM »
Thanks for all the help. I am new to this and this is my 1st bike that I have owned. So if there are any more help sites for the CB750 that I can check out please let me know.
Anyone near the Akron, Ohio area?
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #12 on: November 30, 2005, 07:30:38 AM »
Few hours away......Columbus, Ohio!!
Later,
Greg
    • TVAM
« Reply #13 on: November 30, 2005, 07:33:26 AM »
You won't need any other help sites ...  8)
But if you are a glutton for punishment, you can take a look at:
www.honda-sohc.co.uk (this is a UK site for these bikes - with some crossover membership)
www.hondachopper.com
http://oldmanhonda.com/MC/MC.html
www.oldbikebarn.com
www.satanicmechanic.de
more in the FAQs
SOHC4 Member #2393
Offline dusterdude
« Reply #14 on: November 30, 2005, 09:23:50 AM »
he said glutton...huh huh
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
