Author Topic: need help fast (new symptoms)  (Read 1165 times)
Offline andy8190
« on: August 22, 2009, 09:25:15 PM »
so i am trying to install my hondaman ignition and if i am reading this right the blue wire from the ignition plugs into the blue wire from the coil, but the wire is way to short to reach that far. Am i installing it at the wrong spot, do i install it at the connection by the battery box?
« Last Edit: August 23, 2009, 03:11:33 PM by andy8190 »
Re: need help fast
« Reply #1 on: August 22, 2009, 09:44:29 PM »
The wires from the points plate have a junction near the top rear right corner of the engine, at the frame tubes. This is where you unplug the points and coils from each other and plug the Ignition's BLUE, YELLOW, PURPLE and ORANGE wires in. Don't try to plug them in at the coils: that's the wrong place. Only the BLACK wire plugs in at the coils. The GREEN wire MUST ground at the points plate.
Offline andy8190
Re: need help fast
« Reply #2 on: August 22, 2009, 09:48:36 PM »
thank you hondaman, also i saw a post where you should disconnect the condensers but in the instructions you gave i dont see that mentioned?
brand new condensers if that matters
Offline andy8190
Re: need help fast
« Reply #3 on: August 22, 2009, 10:31:24 PM »
got everything installed and now cant get my bike to start  :'(
Offline andy8190
Re: need help fast
« Reply #4 on: August 22, 2009, 10:53:11 PM »
ok so i got my induction light out and my timing is WAY OFF with my new points plate :(
Re: need help fast
« Reply #5 on: August 23, 2009, 10:41:14 AM »
If you have new points, be sure to clean those contacts with acetone or something.  ;) They will be greasy with cosmoloene.
Gap the points at .014", then set #1-4 side, and it will run enough to fine-set the rest.
Offline andy8190
Re: need help fast
« Reply #6 on: August 23, 2009, 12:45:33 PM »
ohhhhh ok, forgot about that grease
Offline OldSchool_IsCool
  • Really feeling like an
Re: need help fast
« Reply #7 on: August 23, 2009, 03:02:35 PM »
HM,
I grounded mine at the coils and it has worked GREAT for 2 years now.  Isn't a ground a ground?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline andy8190
Re: need help fast
« Reply #8 on: August 23, 2009, 03:08:57 PM »
ok i got the bike started with the points connected without the hondaman ignition. Now i am trying to start the bike with the honda man ignition connected and it WONT START. what am i doing wrong :(
« Last Edit: August 23, 2009, 03:11:13 PM by andy8190 »
Offline andy8190
Re: need help fast (new symptoms)
« Reply #9 on: August 23, 2009, 03:44:44 PM »
if i unplug the purple and orange wires from the points blue and yellow wire, and plug the points blue and yellow into the coils blue and yellow the bike will start but not if i have the purple and orange wires plugged in
