Author Topic: carb question  (Read 2418 times)
farmlife
carb question
« on: August 22, 2009, 09:28:19 PM »
Just bought a 77 cb750. The bike wasn't started for about 13 months. The carbs look real clean and the guy told me that he bought them and had them rebuilt. The carbs are from a 72. I'm having a problem with the float bowls over flowing and running out the tubes. Had problem with 1 and 4. I decided to remove carbs and adjust the floats a little. Put them back on and i guess I over did one because #3 is pooring out like crazy. My question is there a good way to adjust the floats? Once I can get this right I can start from there.
Re: carb question
« Reply #1 on: August 22, 2009, 09:41:26 PM »
The float height on the '72 carbs (models 657A or 657B) is 26mm. This is measured from the little notch on the side of the float bowl nest on the carb's upper half.
It's not uncommon for a tiny burr to grow on the 2 little posts where the pivot pin slides in: this burr is caused by the sharp edges of the brass bracket of the floats. This can make them stick down and overflow. Look closely in there, with the parts removed, and trim off, if found, with a razor blade.
farmlife
Re: carb question
« Reply #2 on: August 22, 2009, 10:27:30 PM »
I was looking at the shop manual and it shoulded a pic of position of adjustment. Pic quility stinks but it also states to use float level guage. Is that the 26mm you r talking about?
Offline Johnie
Re: carb question
« Reply #3 on: August 23, 2009, 07:57:05 AM »
Yes, that would be the float height which is checked with the carbs off the bike...see pic.  The height is checked with the float tang just touching the nipple of the needle valve.  That is why it is easier to do with the carbs off so you can tip them a bit to make that slight contact while you check the floats.  Click the pic to enlarge...
« Last Edit: August 23, 2009, 07:58:48 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
farmlife
Re: carb question
« Reply #4 on: August 23, 2009, 10:12:19 AM »
that is a good idea for those old 3.5 disks. Thanks for sharing that
Re: carb question
« Reply #5 on: August 23, 2009, 12:14:37 PM »
He has a good point, Johnie!
Now I know what to do with some of the 2,230 that I have...  ;D
Offline Johnie
Re: carb question
« Reply #6 on: August 23, 2009, 05:40:02 PM »
To be honest guys, I got that idea from someone on this board a couple years ago.  So I can not take credit for it.  Sure works nice.  Just used my Exacto knife and it works nice for me.
Oshkosh, WI  USA
Offline jimbir
Re: carb question
« Reply #7 on: August 23, 2009, 06:07:28 PM »
I have a picture showing the carbs positioned so the throats are vertical and the floats are hanging down on the pins. The tangs are supposed to be just touching the needles in this position but not compressing the springs in them. In the picture above, the springs are going to be compressed by the weight of the floats Which is the correct way to do this?
Thanx, Jim B.
1976 Honda CB550F
Offline Slayer
  • What can I say that hasn't been said before
Re: carb question
« Reply #8 on: August 23, 2009, 06:28:50 PM »
Find the sweet spot where the pin touches but does not compresses
Offline Slayer
Re: carb question
« Reply #9 on: August 23, 2009, 06:36:09 PM »
Here is the position and tool I did it with. This was before I adjusted, so that is what the float height and tool setting should not look like. I hope it helps
Offline Johnie
Re: carb question
« Reply #10 on: August 23, 2009, 06:48:48 PM »
Thanx, Jim B.
That picture above that I posted was just to show where you set the gauge on the carbs.  Not to do it with them totally upside down.  That tang should just be touching the needle valve nipple and not compressing it.
Oshkosh, WI  USA
Offline Bill/BentON Racing
    • BentON Racing
Re: carb question
« Reply #11 on: August 23, 2009, 06:50:06 PM »
Usually sideways with slight angle,neat float tool,original tool still available from Honda 07401-0010000,$23.50 in 2006 book.Bill
BentON Racing Website
BentON Racing Facebook
