Author Topic: out for rest of year  (Read 1091 times)
Offline KRONUS0100
  • MAD MATT THE MANIAC
« on: August 23, 2009, 07:49:34 AM »
if you recall earlier posts..my cb750k2 motor  was losing power.  Need a full rebuild.  cylinders 2 and 3 are egg shaped...so definitely need the big bore kit.  could see the rings at front and back of pistons on these 2 cylinders.  My guess to the cause would be that is where the primary chains tug the hardest.  Head bolts were tight but the gaskets were blown....sprayed off at car wash and was bubbling and hissing when got home.  When pulled apart there was water between gaskets and jug/cylinder.  i have a k4 donor motot i am going to use the jugs and head off of.  is z1 enterprises good source for cam and primary chain parts?  what is best gsket kit to use?  Money is tight, so both these motors are waiting thier turn at moment.
MATT
Offline mystic_1
  • 1970 CB750K
Re: out for rest of year
« Reply #1 on: August 23, 2009, 07:56:41 AM »
I only use Honda gaskets or Vesrah gaskets now.  Athena gaskets aren't as good.
mystic_1
- John Augustus Shedd
Offline KRONUS0100
« Reply #2 on: August 23, 2009, 07:58:10 AM »
i had heard that about athena.  any others to stay away from?  I heard a couple of people say the bores on the vesrah were off.
MATT
