Author Topic: Correct Key ?  (Read 989 times)
Offline medic09
Correct Key ?
« on: August 23, 2009, 09:28:50 AM »
I received the key(s) and papers to a '76 Trident almost three years ago, that we finally got to bring home the other day.
There is a key on the ring that SEEMS to fit, but the cylinder doesn't move at all.
How can I tell if I have the correct key, as opposed to a stuck ignition lock?
The key blank says Union Made in England on one side.  On the other is a number FS 8844 and names Wilmot Breeden.  The top of the key is more or less square/slightly oblong.
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline 78 k550
Re: Correct Key ?
« Reply #1 on: August 23, 2009, 09:50:06 AM »
try using it in the helmet holder or the seat key if it has one.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline medic09
Re: Correct Key ?
« Reply #2 on: August 23, 2009, 10:00:18 AM »
Thanks Paul.
The bike has neither.
Mordechai
'78 CB750K
Santa Fe, NM
Offline medic09
Re: Correct Key ?
« Reply #3 on: August 23, 2009, 01:31:29 PM »
It looks to be the correct key based on the parts list.  Now we're back to frozen lock... ::)
Mordechai
'78 CB750K
Santa Fe, NM
Re: Correct Key ?
« Reply #4 on: August 23, 2009, 09:41:00 PM »
They all had FS keys but there were many numbers so it could be the wrong key, you used to buy the switch and key barrel sperate so it shouldnt be a big problem
Offline medic09
Re: Correct Key ?
« Reply #5 on: August 23, 2009, 09:54:41 PM »
Thanks Bryan.  I actually got the lock unstuck.  Gave it one last attempt before despairing, and it freed up.  So many of our projects go that way.
I've put together a first-need parts list and will call for prices tomorrow.  Mostly small bits for the moment; but that can add up.
I'm still trying to figure out what the 'mystery hole' is, and what goes there, before I order some bits.  The hole is at the far end of where the starter motor lays, inboard of where the clutch cable enters the case.  I can't find it in any of the drawings I've got.  It has an upraised lip around it, as if some sort of cap fits there.
Mordechai
'78 CB750K
Santa Fe, NM
