Author Topic: Universal Rearsets for most older CB Hondas  (Read 11633 times)
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« on: November 30, 2005, 06:54:48 am »
Okay....here is an old post I had placed on some other forums on making universal rearsets to fit the
older Honda CB's. Most all the CB(twins and inline 4's) Hondas have
1" diam. frame tubes and this works great. I posted this a long time
ago......thought i'd repost it here. This is the
setup i'm using on the CR350 racer and i'm now see some of the
vintage road racers using this setup.....enjoy!!
Very easy and functional way to get some very nice rearsts
for most cafe bikes with very little metal fab or machining.
1. Purchase 4......universal 3-Piece 1 inch frame clamps from Dennis
Kirk(800-323-9280), part number=h27-036.......$5.99ea.
2. Need to look on EBAY for 1998-2002 Honda CBR929RR/RC51
rearsets....usually run approx. $80 per set. You will need the
rearset brakets(right & left), both heel gaurds, shift lever, & rear
brake lever with return spring(and brake light switch if using a taillight). You can usually find all these
together as a set or with only a few parts missing or damaged. I have
purchase a few sets with road rashed pegs for very cheap. Usually, you
can purchase some aftermarket pegs from the local bike shop for around
$20.
3. Purchase some smooth round rod(have to thread ends) or threaded rod($1.57 for 3 foot piece...approx) from
local hardware store to fab up the shift and rear brake linkages. I
have always purchased smooth round rod, then once cut to
size.....threaded the ends using a tap/die set.
4. Depending on application, you may need to use a spacer between the
frame clamps and the rearset mounting braket. On my CB350's I have
used a 1 inch aluminum spacer to locate the peg out away from the
swingarm for clearance.
I have some pics on my website of these rearsets being used on my 1972
Honda CR350 and also on my 1970 Honda CB350RR Inverted front fork
hybrid. Feel free to visit the site at:
http://www.OHIOCAFERACERS.com
These rearsets have worked great for me, hope this helps for you cafe
project.
Greg
Below is an old pic of the rearsets during mock up:
« Last Edit: November 30, 2005, 06:56:41 am by ohiocaferacer »
Offline dusterdude
Re: Universal Rearsets for most older CB Hondas
« Reply #1 on: November 30, 2005, 07:05:19 am »
steve,can you put this in faqs please,seems like good info
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #2 on: November 30, 2005, 07:05:57 am »
I was just about to ask Mr Ohio if he'd mind...
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline dusterdude
« Reply #3 on: November 30, 2005, 07:06:41 am »
aint if funny how smart minds think alike
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
    • OHIO CAFE RACERS
« Reply #4 on: November 30, 2005, 07:07:03 am »
Feel free to use as needed.....
Offline tsflstb
« Reply #5 on: November 30, 2005, 10:34:55 am »
These look really nice.  Do you have more details/pictures on how you mounted the rear brake rod to the pedal?  On my 400/4 there is a tube on the frame that a splined shaft rides in and connects to the foot pedal to the brake rod.  I'm assuming you wouldn't use this and instead connect the brake rod directly to the pedal.
Do you need to fabricate a special adapter clevis to mate up to the pedal?  Is there already a "cam" on the backside of the pedal that can be used to actuate the rod?  Should I get a right rearset with the master cylinder in place to scavenge some parts?  Thanks again for this post.
Offline Raul CB750K1
« Reply #6 on: November 30, 2005, 01:11:16 pm »
Isn't that a CB350 Twin? Don't ask me how I know, I spend more time with it lately than with anybody else
Raul
P.S. Those rearsets looks terrific!!!
    • OHIO CAFE RACERS
« Reply #7 on: November 30, 2005, 02:56:42 pm »
Heres some more detailed pics of the rear brake rod that connects to the rear brake lever. With the CB350t, I just made a new brake rod that attachs to brake lever at the rear wheel(you have to flip the bracket on the rear brake backing plate up). There are a ton of pic at my website.....look under CR350.
You can purchase the Self-Aligning Chrome Rod Ends at DennisKirk.com....they run $15.99ea. I used the Rod End w/  5/16"-24 stud(one on the right).
Heres a link to the rod ends:
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=H571007#altImages
The first pic below is the 1" alloy spacers I used between the rearsets and the 3-piece clamps.
Offline tsflstb
« Reply #8 on: December 01, 2005, 05:18:24 am »
Thanks alot.  I would never have thought to look through the Harley section of Dennis Kirk for any of this stuff.
Offline Gregorymoto
  • SOHC Aficionado
« Reply #9 on: December 04, 2005, 02:23:44 pm »
You can also find some rear sets off of a CBR FZR GSXR and make a adaptor plate.
I did mine for $25. and spent 2 hrs making the plate then bolt on bolt off.
The plate bolts off the frame the sets bolt on the plate.
Yep, i have issues with this sort of stuff.
rucorey
« Reply #10 on: December 30, 2005, 02:49:04 pm »
Guys-
Just FYI- If you have a 750 the frame size is 1 1/8" id. I Dennis Kirk was low on stock so I ordered from this place. No idea how long it will take to ship (def not as fast as DK!)
http://www.freelperformance.com/
gsnorcal
« Reply #11 on: December 29, 2010, 10:34:03 am »
Anyone have a picture of where the rear drum rod attaches to the brake lever? I don't understand where the leverage comes from since the hydraulic rear brake doesn't use the "L" shape because they just push a rod up into the MC.
Thanks,
Dave
Offline Grnrngr
« Reply #12 on: December 29, 2010, 10:49:30 am »
Watching with interest....
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline climbingaz
« Reply #13 on: December 29, 2010, 10:51:49 am »
Great info!  :)
Offline Brandotheamazing
« Reply #14 on: December 29, 2010, 02:54:20 pm »
defenatly going to look into this, as using 400f controlls on my 550 didn't quite acheave the location i wanted for my feet.
-Brendan
Offline lone*X
« Reply #15 on: December 29, 2010, 03:02:44 pm »
You guys do realize this is a 5 year old thread, right?  OP is still around though so you may get something but I don't think it is a current project.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Grnrngr
« Reply #16 on: December 29, 2010, 03:53:26 pm »
a ZOMBIE thread!!!!   ;D lnterest remains...
'77 CB750A
Offline eideteker
« Reply #17 on: December 29, 2010, 05:29:43 pm »
Rookies ask a question and get bombarded with search results; rookies search and bring up an old topic and get railed for that too...can't win for losing sometimes.
Good information never gets old.
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
Offline Grnrngr
« Reply #18 on: December 29, 2010, 08:30:56 pm »
+1!!  Big props for a guy that does some searching...I've been on here a while, but not long enough to have seen this one....... I'm diggin it...and I see some familiar names, guys who are still active...speak out bros, have you tried it? how's it workin for ya? oughta have the bugs worked out by now.. ;D
'77 CB750A
    • OHIO CAFE RACERS
« Reply #19 on: December 30, 2010, 10:41:57 am »
Thanks,
Dave
I'm still around...although not on here as much as i'd like.
This was a setup I developed to be used on the CB350 twins. The rear brake rod attaches to the stock master cyclinder location on the rear brake pedal of the CBR pedal. The throw of the leverl is very small, so you have to adjust the rear brake to accomidate for this.....or you can cut the pivot off the rear brake pedal and re-weld it into a location that gives more leverage on the rear brake. I have rewelded these before with my tig....and they weld very nice.
One thing you have to be careful with is......some modern rearsets on other makes dont have the pivot in the correct location and will need to be moved and rewelded.
gsnorcal
« Reply #20 on: December 30, 2010, 01:39:49 pm »
Thanks! That's just the information I was looking for. I could see on your 350 pictures (on your site) that the lever throw looked short.
Thanks,
Dave
Offline Jim F
  • go baby go
« Reply #21 on: January 06, 2011, 04:26:30 am »
 I was wondering about the clamps
on the frame rails
How are they attached? where did you get these from or did you make these?
If you made them can you send a print?
thanks
Jim
www.jmfmicroweld.com
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline GHST_TGR
« Reply #22 on: January 06, 2011, 09:18:38 pm »
big-jim,
forgive me if I am misunderstanding your question but everything you've asked is addressed above.
Offline Jim F
  • go baby go
« Reply #23 on: January 07, 2011, 02:33:10 pm »
Your right
I just blew threw the pics and didn't bother
with the text
 thanks for the ideas
Jim
« Last Edit: January 07, 2011, 03:49:37 pm by big-jim »
