Author Topic: starter clutch problems  (Read 769 times)
Offline Outboardbill
« on: August 24, 2009, 03:30:46 PM »
My 1978 cb750f is running.  It had been sitting since 1986.  So far I have only had it at idle speed.  I think I hear the starter motor continue to turn while it is running.  I checked the solenoid and even installed another one just in case.  Has anyone ever heard of the starter clutch sticking on these bikes?  Thanks, any advice would be greatly appreciated.
Offline mystic_1
  • 1970 CB750K
Re: starter clutch problems
« Reply #1 on: August 25, 2009, 05:30:20 AM »
Starter clutch can stick, it's behind the alternator rotor and consists of three spring loaded rollers.  If the springs and plungers get gummed up then can stick in either the engaged or disengaged position.
To inspect you'll need to remove the alternator cover and pull the rotor off the end of the crankshaft.  The first is easy, the second not so much, so eliminate other possibilities first.  Once the alternator cover is off you can test the starter clutch by moving the starter gear that's behind the rotor.  It should roll easily in one direction and not at all in the other.  That'll tell you whether you need to pull the rotor.
mystic_1
- John Augustus Shedd
« Reply #2 on: August 25, 2009, 05:50:25 AM »
Thanks for the help.  I'll pull the cover and check.
