Author Topic: SOHC4.net screensaver  (Read 1101 times)
Offline Zaipai
    • My Home page
« on: August 24, 2009, 07:19:13 PM »
Hi all, not sure about this but I have put together a screensaver of images found on this forum. If there is enough interest I will put together an installer for it and host it some place with good band with speed.
That said, this is a first pass. I wanted to use some one else's framework for it but if this takes off I will write my own code since this one is kinda slow and is rather old.
Anyway.. I am just taking pictures I find on the forums of Honda SOHC bikes and so not all of our bikes are there. At some point there will be since I am doing this more for me then anything.
All you need to do is click on the links below and save them to your C:\windows\system32 folder, or where ever your system32 folder is. It should work with Windows2000, XP, Vista and Windows7. Its my server at home and the uplink speed is not great so please be patent. As I work on this I will probably add captions.. and perhaps images that have to do with CB's also any suggestions are welcome, even ones that ask me to remove their bike from the screensaver.
Again its just the first pass so please be kind with the comments.. ;)
http://zaipai.dlinkddns.com/screensaver/HondaCB4s.scr 618kb
http://zaipai.dlinkddns.com/screensaver/HondaCB4s.sff 34mb
Its my Avatar..
75 CB550F  |
Offline Ecosse
  • Member #4139
    • My 550 walk around video
Re: SOHC4.net screensaver
« Reply #1 on: August 26, 2009, 01:52:22 AM »
that's very cool of you zaipai! there are some really good images floating around here. check out past botm and inspiration galleries. if i fine anything i can pass it along.
1974 CB550K
                                  Your 1%er name
Offline Zaipai
    • My Home page
« Reply #2 on: August 26, 2009, 08:31:54 AM »
Thanks I will keep looking. I am finding some in the gallery also. For now I am just doing member bikes, the good, the bad and the ugly because they all have a place and all have some quality worth looking at. Its a slow progress however I will get it there.
If we (as forum members) want a wider range of bikes I sure could add them easy enough.
Its my Avatar..
75 CB550F  |
Offline chips1953
  • Chips1953
  • So many roads and so little time
« Reply #3 on: August 28, 2009, 02:21:41 AM »
I guess this won't work on a Mac?
CB750 F1 1976
Offline Zaipai
    • My Home page
« Reply #4 on: August 29, 2009, 07:06:53 PM »
No, however I have dusted of my Powermac and I am seeing what I can do. I have found the frame work I am using can cause the machine to lock up if its left too long. I can't seem to find the memory leak so I am going to enlist some help from some coding friends. Also I would like to see a Linux one cause I prefer Linux over Windows.
So the short answer is no, I am working on it...  ;D
Its my Avatar..
75 CB550F  |
