Author Topic: 78 cb550k owners  (Read 1210 times)
daredevilsadvocate
78 cb550k owners
« on: August 25, 2009, 08:07:33 PM »
Anyone working on their bike currently who could take a picture of the two stems that connect where the choke meets on the carbs with the springs and what not?..I've attached a microfiche on where I am talking about...and thanks in advance!!
~dd
Re: 78 cb550k owners
« Reply #1 on: August 25, 2009, 11:14:59 PM »
Will this do?
daredevilsadvocate
« Reply #2 on: August 26, 2009, 07:14:05 AM »
It helps immensely ...thanks a ton!!....does that main part of the choke wheel come up into the throttle wheel? or is that to the right of it?...I can't tell by the picture....thanks!!
~dd
« Reply #3 on: August 26, 2009, 09:26:06 AM »
It's to the right of it. The choke cam lines up with the adjust screw on the throttle wheel.  That's the fast idle cam.  When choke is applied, the throttle is opened somewhat.
daredevilsadvocate
« Reply #4 on: August 26, 2009, 09:12:24 PM »
Thanks Two!...That pic helped immensely!!
~dd
**thinks to self**..."self...i knew i joined this forum for a reason"...**   :D ;) :)
