Author Topic: Question about CB550 airbox  (Read 18504 times)
Offline Weeburn
Re: Question about CB550 airbox
« Reply #25 on: May 12, 2013, 03:38:08 PM »
The fitting at the top of the engine goes to the side of the filter box (NEVER the air plenum chamber).  The filter box also has a drain tube at the bottom that is capped.  The cap has a slit in it, that is pinched at maintenance intervals to drain collected water condensate.
The bottom of the filter box has the parts you see in the picture you posted.  Those parts; gasket, foam element, and metal assembly are there to keep the engine vapors from fouling the air filter element.  It will ruin the stock paper element very quickly with oil and water vapors/droplets.    The foam UNI type will survive this much better, but the cleaning and re-oiling interval will shorten.
I stumbled upon this thread while looking at options to replace my air filter, and thanks to it I realized when I installed my stock airbox (bike came with pods) I hooked up the hose wrong, to the air plenum chamber as you said never to do. I've been riding it around and it's been running pretty good, what are the results of having the hose hooked up here? Running richer from burning oil vapors differently than if they went through the air box, or risk of condensed liquid oil building up and getting sucked in, or what?
Offline Untold
« Reply #26 on: May 13, 2013, 09:25:11 AM »
For those asking what to plug the airbox drain hose with, I just snipped a 2 inch piece of spark plug wire and shoved it in the tube.  Fits nice and snug, and has about an inch left sticking out, which I just grab with pliers and pull out to drain.  Then shove it back in until next time.
1976 CB550K
« Reply #27 on: May 22, 2013, 11:14:19 PM »
When everything works perfect, the engine breather to plenum connection will work ok for the interim, I suppose.  I never attempted to run it this way.
It's when the carb bowls overflow with gas that the risks become significant, as that air plenum drain tube is supposed to route pooling gas under and away from the bike, rather than filling the plenum chamber, and engine cylinders/oil sump with gasoline.
A plenum filled with gasoline, and a backfire though the carbs might just ruin your day.  But, it IS thrilling to live life on the edge and take any risk that comes along.
I prefer to minimize risks, as there are plenty of things that can go wrong even if one doesn't rearrange things that aren't fully understood.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #28 on: May 23, 2013, 03:26:05 PM »
Welcome back TT :-)
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Gman
« Reply #29 on: May 28, 2013, 02:44:25 AM »
Welcome back TT :-)
+1
And, for those of you wondering what/how/why the airbox is set up properly, see Sohron's build.  It is beautifully detailed.
http://forums.sohc4.net/index.php?topic=86697.100
The airbox section is page five, but it is worth reading the whole build!
G
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
« Reply #30 on: August 03, 2014, 08:37:18 PM »
I stumbled upon this thread while looking at options to replace my air filter...
+1.  I've always used the stock paper filter but they are pricy.  Is the Uni NU-4055 a good replacement?
I can buy it locally for $20....
http://www.powersportsuperstore.com/Uni-Air-Filter-NU-4055-p/4116511.htm?Click=35177
Offline flatlander
« Reply #31 on: August 04, 2014, 03:44:34 AM »
i think TT is using one and seems happy with it.
i've gotten one recently but don't have enough kilometres/miles on it yet to comment.
Offline goldarrow
  • one day, i'll be an
« Reply #32 on: August 04, 2014, 07:48:16 AM »
I've been using uni filters on all my bikes 550s and 750s no issues
CB550 K0
« Reply #33 on: August 04, 2014, 07:54:49 PM »
Thanks guys, just ordered 1.
Offline Nrgcreator
« Reply #34 on: May 04, 2020, 12:32:29 PM »
Been collecting hardware to get the airbox back in, have just a few pieces left. Someone was kind enough to share a link to the shop manual (http://manuals.sohc4.net/cb550/) but chapter 8 is missing! Anyone have a digital copy of chapter 8 you can share?
Thanks!
1974 CB550K
