Author Topic: Homemade master cylinder rebuild tool  (Read 5190 times)
mojomoto
« on: August 30, 2009, 10:36:06 AM »
I lucked out in making a tool to help put the piston and seals back in after cleaning the gunk out of my master cylinder. I found a short piece of common half inch water pipe, deburred it and polished the inside. To use it, lube the inside with some fluid, push all the parts into the tube then slide them into the cylinder with a small deepwell socket.
