Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
This is not a pod threadThis is not a #$%* on my vacuum gauges threadThis is a help or GTFO thread.
I'm not sure what you mean by lateral movement but i'll check out the FAQ's.
I have this same exact problem. F on neutral is perfect but when revving goes way past the two ||
Quote from: Dos on April 15, 2018, 12:29:05 amI have this same exact problem. F on neutral is perfect but when revving goes way past the two ||Then breakerpoints gap is not correct, probably too wide. Adjust. But, bear in mind, a few degrees extra advance won't hurt. It can even make your bike a bit livelier.
I didn't post that. A few degrees like 2 to 3 extra advance is no problem. Quotebut when revving goes way past the two || 'Way past' could be a problem.
