Author Topic: Helmet smells like gym cloths...  (Read 1192 times)
Offline cleveland
« on: August 31, 2009, 05:26:12 PM »
I'm sure I'm not the only guy who's helmet will begin to smell like gym cloths after riding a few weeks in hot weather.  Normally I take a rag with dish soap and wash the lining, then stick it in front of a fan to dry.  This works OK, but never completely does the job.
I have been thinking of making something to stick into my helmet that will absorb moisture.  At first I was going to use the gel pack, like the ones that keep my gun cabinet dry.  Then I figured a better idea would be to use cedar chips in a cotton bag and mix in some gel pack.
What do you guys use to clean your helmets and keep them dry?
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: Helmet smells like gym cloths...
« Reply #1 on: August 31, 2009, 05:32:14 PM »
febreeze it, and you might try putting a small bowl filled with baking soda on a flat surface then put the helmet over it. thats how i descented my riding helmet
Mark Twain - Notebook, 1894
« Reply #2 on: August 31, 2009, 06:02:03 PM »
there are several commercially available products like this: http://www.cyclegadgets.com/Products/product.asp?Item=HFRESH
Many helmets have removable liners for washing. Or you can wash them in place, and dry with hair dryer etc.
But I've found the deodorizers to work fine.
« Reply #3 on: August 31, 2009, 06:04:34 PM »
If your helmet smell is annoying you, you've probably got it on backwards............. ;D
Offline kirkn
« Reply #4 on: August 31, 2009, 06:18:43 PM »
a big +1 on the Febreeze.  Spritz it in until the padding is pretty damp.  Let the helmet sit upside down overnight until the Febreeze evaporates.  As it evaporates, it seems to take the smell with it, leaving a complete neutral, non-smell.  At least, it always does for me.
Kirk
Offline Steve F
« Reply #5 on: August 31, 2009, 06:22:38 PM »
I was fairly successful with using WOOLITE to soak the parts of the helmet liner that aren't removable...soak, massage, soak some more and rinse in luke-warm water.  Lots of grunge and dirt came out and THAT surprised me!  It wasn't smelling bad (yet) but it sure helped with freshening up the liner.  I just bought a SHOEI helmet that has a totally removable liner and pads that can be cleaned and put back in.
Offline IAmCitizenMe
« Reply #6 on: August 31, 2009, 06:27:46 PM »
When my shoes would smell so bad from skateboarding that I couldn't wear them in the house, I would put newspaper and baking soda in them and set them outside for a while. I don't know why, but it worked.
Offline mrblasty
  • Expertly
« Reply #7 on: September 01, 2009, 12:15:42 AM »
I wonder if that would work for two week old pants? :-X
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline Raul CB750K1
« Reply #8 on: September 01, 2009, 06:38:25 AM »
My helmet have removable liners. I have removed and cleaned them a couple of times, but it is not that simple, as a part of the helmet trim had to be unglued.
Then I tried the dry cleaning, a spray that will make a foam and you just rub and let dry. Sure, it smells better, but where did all the dirt go?
So I read about it in an spanish forum, tried and now it is my favourite way of cleaning the helmet. Just put it in the bathtub and clean it with lukewarm water and clothes washing soap. Clean, rinse, clean, rinse, until water gets out just clear -it is amazing the amount of dirt the liner can get-. Once cleaned, let it dry at air temperature for a couple of days.
Yes, I know, somebody will chime in saying that "water temperature will damage the styrofoam inside" etc. That is because your head never rises the styrofoam temperature to 37ÂșC or the Sun never rises the temp. either.
Lukewarm water, soap and you are good for some weeks or even months.
Offline Operator
  • Someday I will live up to being a
« Reply #9 on: September 01, 2009, 06:50:48 AM »
Wash your helmet????
I usually drop it in the driveway/garage so often I end up replacing mine every 2 seasons so it doesn't have time to stink up too much.  Mind you we don't ride year round up here.
Wearing a bandanna or beanie underneath works too, just toss it in the regular wash.
If ever there was a creator of bastard sons, it is the open road, for she has claimed so many young men yearning for freedom......
1973 CB750 K3
1976 CB400F (Cafe Project)
1979 Yamaha XS400 (Currently up for Sale)
Offline cleveland
« Reply #10 on: September 01, 2009, 06:52:20 AM »
Nice to see all the feedback!
I have a Shoei Multitech and only the cheek pads are removable.  :(  I think I will try a combo of stuff I have read here.  I will use the baking soda & Frebreeze as a regular maintenance and then wash it in the tub every few weeks. Being someone that has Mediterranean heritage, I have quite a bit of oil in my perspiration and your scent is carried in you oils.  So regular maintenance is a must!  *disclaimer*  If you are of Mediterranean decent and the last statement offends you, suck it up!  You know your oily too!  :D
Why you son of a.... ;D
« Last Edit: September 01, 2009, 06:56:00 AM by cleveland »
« Reply #11 on: September 01, 2009, 07:03:28 AM »
yes I've taken to wearing a "Slik" brand helmet liner, which can be easily washed.
http://www.webbikeworld.com/r3/helmet-liner/
Another benefit is that on hot days, I soak the liner with water, put it on, and then the helmet, and the evaporation over the next hour or so keeps my brain cooler. By the time of the next gas stop its completely dry.
When putting one on, I always feel like a baby with a crib cap. But at my age who cares? it works.
« Last Edit: September 01, 2009, 08:03:15 AM by MCRider »
Offline Operator
« Reply #12 on: September 01, 2009, 08:01:11 AM »
"baby with a crib cap"
I'll have to try that!
1973 CB750 K3
Offline coldright
  • That's Ms.
  • to you
« Reply #13 on: September 02, 2009, 03:12:01 PM »
Spray the liner with rubbing alcohol.  It kills bacteria, bacteria is what makes it smell.  You can use an alcohol solution on your underarms too, if your skin doesn't get dried out from it.  Mix it with a little essential oil of a scent that you like.
Offline Operator
« Reply #14 on: September 08, 2009, 06:27:59 AM »
Have to try that one sometime.....
1973 CB750 K3
