Author Topic: Pipe-to-Head Exhaust, fixing method  (Read 1770 times)
Offline beveldrive
« on: September 01, 2009, 10:13:49 AM »
I'm confused
In my research there seems to be several exhaust pipe-to-head clamping methods used across the sohc 750 range.
Mine, a K7 with Motad, has the ends of the pipes formed into a narrow flange, all held in place with split collars, M6 studs and finned clamping ring. Then on some I see a drilled diamond shaped flange, loose on the pipes. Presumably this locates on studs and facing a ridge on the pipe, provides the clamping with no finned ring at all!
Can either method be used on the sohc 750 - assuming the profile machined/cast into the port opening is the same for all motors? :-\
Thanks
Steve ???
Offline scondon
  • Mmmm......tasty bugs
Re: Pipe-to-Head Exhaust, fixing method
« Reply #1 on: September 01, 2009, 12:04:02 PM »
Yes, both methods can be used. Kerker pipes are a common aftermarket exhaust for the 750's and have the diamond shaped flange you speak of. Diamond flanges can be bent if over torqued, finned collars are more robust. Bent diamond flanges don't affect seal, they're just a little harder to locate over mounting studs.
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #2 on: September 01, 2009, 02:36:05 PM »
Either method can be use to attach, but sometimes there can be interference at the rear muffler mouting area or underneath.
 Here are the 2 stock styles header mount
 Early ' spigot" mounts
 Later split collar mounts
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline Johnny5
    • CB350F build thread
« Reply #3 on: September 01, 2009, 06:30:50 PM »
It's certainly easier to mount the header to the earlier flanges than the later style. But I wonder if the later style mounts get a more positive lock onto the head?
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline beveldrive
« Reply #4 on: September 01, 2009, 10:03:05 PM »
Thanks Guys, Things are getting clearer now!
How all this question came about was I'm rebuilding my K7 in the style of an endurance racer and have recently got a new (but old stock) Marvick 4-into-1 off ebay. What I want to do is spring mount it. Looking at some pics of a Lawson Replica Kawa, this seems to be acheived by having flange plates mounted to studs about 50mm off the head, and the pipes a sliding fit in the plates. Trouble is, to do this I'm gonna have to cut the pipes to get the flanges on :'(
Offline voxonda
« Reply #5 on: September 02, 2009, 02:02:26 AM »
Hey Beveldrive,
Like to see pic's of your bike, am a endurance fan myself. This is how I am doing it with the engine I am building now.
Good luck, rob
Offline CBJoe
« Reply #6 on: September 02, 2009, 03:27:52 AM »
Pardon my ignorance, I've only had CB650's with the split collar mounting type.
I thought that the header pipe mounted "over" the spigot and not "into" the spigot.  What seals/holds the pipe in the spigot above??
Regards, Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline voxonda
« Reply #7 on: September 02, 2009, 03:51:45 AM »
Regards, Joe
Hey Joe,(Great song, isn't it?)
You are right. This was the setup for my Turbo engined CB750, and I used a smaller diametre tube for that, due to gasspeed in the system. For a 'normal' 4 into 1 the diametre will mount over the spigot's. For the Turbo I used a sealent from the automotive industry, sorry but forgot the name.
Cheers, Rob
Offline beveldrive
« Reply #8 on: September 02, 2009, 10:33:16 AM »
Hey Rob,
that's a nice bit of machining on those exhaust clamps!
I don't have any pics to show yet as my bike is in its very early stages, but I'll be posting some when things develop.
At the moment I'm waiting for parts to refresh the motor - chains, seals, gaskets etc.
Regards
Steve
Offline voxonda
« Reply #9 on: September 02, 2009, 11:40:42 AM »
Hey Rob,
Regards
Steve
Hey Steve,
Anything special to be done to the engine? Or refreshing it and give her a good tune?
Clamps made for my (ex) Turbo bike and made new ones for the engine I am building now. Clamps can be made available. Hope making her fast but still reliable.
Been riding my sons Triumph T595 for a few days now and man wished we could make the old girl fast enough to keep in her wheeltracks. Or am I just getting a bit old for these new(er) toys?
Cheers, Rob
Offline babyfood1217
  • The only way to drink espresso is as a
  • I miss my baby...
« Reply #10 on: September 03, 2009, 06:49:50 AM »
I have always love these setups.  I usually see them on race bikes when I go watch the track days, but I think it would be super simple to mod the already existent spigots I've got to make something like this happen.
Has anyone else thought about or tried something like this on these older bikes?
I need help moving my project bike from Wisconsin to Seattle, WA.  Willing to pay well.  Contact if interested.
SOHC member: #438
Project: 1976 CB750K
GSXR forks, Monoshock Rear end, 836 in progress, RC51 pipes, custom frame and everything else.
