The SOHC/4 World Tour is in under way.
I know the 750 swing arm is a little longer but can't find any measurments on it.
Quote from: Beans on September 01, 2009, 12:20:40 PMI know the 750 swing arm is a little longer but can't find any measurments on it. As a heads up, I read in Hondaman's post that the 750 swingarm is actually shorter than the 550: http://forums.sohc4.net/index.php?topic=55936.0
'86 ninja swingarm, '75 cb550Fswingarm is a little narrower than the CB swingarm, a couple inches longer and the axle bolt is a bit smaller,, pivot bolt is the same diameter so I will have to hog out the swingarm a bit to make the cb axle work
