Author Topic: head shake  (Read 1216 times)
Fratino880
head shake
« on: September 02, 2009, 10:40:44 AM »
I have a 1974 cb 550 that has a head shake issue. I put drag bars on the bike and took off the front fender. I dont think this contributes to head shake but when i am decerating with the throttle closed i notice wobble in the front wheel. If i grip the bars tight it is not an issue but as soon as i take a hand off i notice the wobble but it is only when decerating. Does anyone have a clue what this is from. My head bolts are all tight and the rim dosent seem to be bent.
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
Re: head shake
« Reply #1 on: September 02, 2009, 10:51:13 AM »
What is the condition of your steering bearings?  Loose?  Notchy? Also check that your forks are square in the triple clamps by first checking the torque of the axle nut, loosening one of the forks in the triple clamps and then compressing and releasing the front end.  Then tighten the triple clamp bolts.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline mystic_1
  • 1970 CB750K
Re: head shake
« Reply #2 on: September 02, 2009, 10:56:53 AM »
The front fender's bracket does double duty as a brace to keep the fork lowers from twisting relative to each other.  If you stand over the front wheel and hold it still with your legs while turning the bars back and forth you'll see the flexing.
Reinstall the front fender and see what happens.
mystic_1
- John Augustus Shedd
Offline SanDogDewey
Re: head shake
« Reply #3 on: September 02, 2009, 07:52:27 PM »
mystic_1
I agree, put the fender back on, or install a fork brace.
Offline mystic_1
  • 1970 CB750K
Re: head shake
« Reply #4 on: September 02, 2009, 08:03:45 PM »
If you want the no-fender look, drill out the rivets and just install the bracket.
mystic_1
