Author Topic: 1976 CB550F oil leak?  (Read 1160 times)
Offline AGB-1
« on: September 03, 2009, 04:10:49 AM »
 I have an oil leak in the clutch area on my CB550 and was wondering if there is a seal for the kickstart pedal on the inside? The oil pan gasket needs to be replaced, but the other leak is a steady drip from the rear engine frame bolt. The leak is bad enought to keep me from starting the engine. I have looked at the parts diagram, but I have not removed the clutch cover yet,because I have no gaskets or seal(s). Anyone experience a similar problem? Thanks AGB-1
