Author Topic: "Holly" CB750K 1978 --Project: Toecutter Zen Mistress  (Read 34236 times)
Offline rooky
Re: "Holly" CB750K 1978 --Project: Toecutter Zen Mistress
« Reply #150 on: July 02, 2011, 01:03:27 PM »
hi i've only just seen your thread
i have a swinging arm very similar to carpys but it was on my bike when i bought it in 1981 i was under the impression they were made by read titon not dresda but anyway the bearings are taper rollers
the id is slightly larger than the stock swinging arm spindle and a tophat spacer is pushed into the bearing to sleeve it for the spindle and to locate it in the frame
i think he is a bit cheap not to sell the bushes with the swinging arm but there again most of the stuff he sells seems to be designed to appeal to people who are attracted to shiny things
rickman honda 900
cb750 k6
triton (most of)
cb750 hardtail chop - mid life crisis project
« Reply #151 on: July 02, 2011, 01:10:34 PM »
I thought Carpy's swingarms came with brass bushes...
Offline motocyconomad
« Reply #152 on: July 03, 2011, 08:03:09 AM »
either way the one he sent me aint for a 78 frame so I gave it to my buddy pretty cheap. I'll make my own from titanium way better. I like things light and super strong.
« Reply #153 on: August 19, 2011, 08:52:22 PM »
turned out the dyna went bad I think since I pulled the motor and stuck the stock bikes motor in I'll take the head off an send it to Mick R. for a simple port/polish
the motor needed the carbs jetted bigger because of the pods and 4-1 exhaust
the GPS is nice I use it as a speedo it can track long trips too
glad to be able to ride it more than work on it lately...
still need duel disk brakes in front ,rear disk conversion installed, Randakk oil filter adaptor, put the Lester on front, SS seat pan and tail cowl,Ti swingarm, then build out motor/motors
Offline lucky
« Reply #154 on: August 19, 2011, 09:43:22 PM »
sunday i
went and got the bike with George and his truck and trailer. now I have it right here to work on and clean. after dropping the bike we went to George's house; he got his bike out and got on it and let me ride around the block... all I got to say is that, that is the fastest bike I have ever rode, super-scaryfast. that thing could probably do 200mph with the right sprocket. I rode on the back for a little, he scared the hell out of me. I thought I might die. after that I went home. His girl I could tell was super pissed, but was trying not to show it. He might have the fastest 1978 CB750K in Houston maybe even Texas. I would be glad to make my bike half that fast. It is sick.
Lucky supervises in the foreground
pulled old carbs, they don't look to bad inside.
that thing is outta here
cleaned a bit, think I am going to lose the key
start just have a secret switch and push the
button
got a new old harness and it looks differant from
mine I think i am going to make my own wiring
this is the thing that gets me nervous I hate
wiring, pretty sure I am going to go with the toecutter front fairing
What is that thing on the bottom of the battery box?
"That thing is outta here"
« Reply #155 on: August 19, 2011, 11:06:23 PM »
...we know who you are bronze...we remember the the night rider and we know who you are bronze...
Offline vozzy
« Reply #156 on: August 23, 2011, 05:53:54 AM »
Nightrider looks like Lemmy with short hair, and Toecutter looks like King Buzzo from the Melvins. . . Best part of Mad Max was Goose's bike, even if it was a "Kwaka" saki. . . "See you on the road, scag". . .
Offline lucky
« Reply #157 on: August 23, 2011, 08:35:52 PM »
I am getting so pissed off, I must find my zen, I must chill out I will find a solution to my electrical ignorance.
need advice:
1. what kind of electrical components are best ie... reg rec fuseboxs???
2. is it really this hard to get the CR carbs in the boots any tips??? lube??
3. when I got 1 broke spoke should I change them all???
Just order the brand new 1976 wiring harness and forget all the other stuff.
Get a reg/rectifier combo from Ricks Motorsports.
Just go with all 1976. It will be easy and you can get all the parts.
« Reply #158 on: August 24, 2011, 06:10:02 AM »
that would work for a 76 but I got a 78!
finished the electrical
got a reg/rec and fuse box
had the right boots sent
ya sent the wheel to Buchanans they sent the wrong spokes they put it together
« Reply #159 on: October 10, 2011, 10:53:02 AM »
#$%* that fiberglass #$%*, stainless steel lives forever! 18 gauge.
I'll do a little more fitting then get it upolsterd real nice
Offline lucky
« Reply #160 on: October 11, 2011, 07:33:23 AM »
need advice:
Answer question#1.
Get the stock OEM fuse box.
Rick's brand regulator rectifier unit combo.
The rest just stock components.
You already have the ignition and coils.
Answer Question#2.
Are the carbs hard to get into the boots?
You will find out as soon as you try.
Don't have anxiety by thinking too far ahead.
Answer Question #3.
Just replace one spoke unless the rest are all rusted.
Inspect all the spokes when the wheel is all apart. THEN decide.
Thinking too far ahead again. Will cause anxiety.
Offline WhyNot2
  • I'm finally an
« Reply #161 on: October 11, 2011, 07:57:59 AM »
subscribed..............................
« Reply #162 on: October 11, 2011, 07:55:08 PM »
need advice:
Answer question#1.
Answer Question#2.
Answer Question #3.
That post you are answering is 2 years old.... :o
« Reply #163 on: October 12, 2011, 07:54:44 AM »
ya I solved all that a long time ago. I'll up date with a full video when I'm ready and I figure out a good camera mounts.
