Author Topic: Still having trouble.  (Read 790 times)
andy1976
« on: September 06, 2009, 04:25:49 AM »
My bike isn't running properly and I'm getting really p'ed off with it. I got it running in june, everything cool, then i had a pretty bad oil leak(now fixed) then 1+2 weren't firing, tested it yesterday it's only firing on #4.
Did a compression check this morning.
Test results  No.1  135 psi
                  No.2  120
                  No.3  110
                  No.4  150
This was done on a cold engine as it won't run properly to get it warm.I've got fuel on the plugs and a decent spark
Could this be the head gasket blown or piston ring trouble?
Cheers
Andy
Offline crazypj
  • I'm brill, me
Re: Still having trouble.
« Reply #1 on: September 06, 2009, 04:49:56 AM »
Could be rings or valves.
 Its not so low it wont run, just wont run properly
 You did have throttle wide open when you did test?
 Plugs wet?
 Could have carb problems as well?
 Remove carbs and clean them.
 Check valve adjustment.
 Get a leakdown test done, then you can check general area (intake  and/or exhaust valves and/or rings, depending where air is leaking)
PJ
Offline Brian G
« Reply #2 on: September 06, 2009, 06:33:48 PM »
Hi Andy -
If she was running well prior to the oil leak repair, I'd guess that something went amiss during the repair job. If it affects 1 & 2, then it's probably not ignition related, as that would affect 1 & 4, 2 & 3 or all four cylinders.
IME, a blown head gasket wouldn't stop the engine from running, it would just make it messy; ditto with rings. Did you have to remove the head to repair the oil leak? If so, are you sure the valve timing is set correctly? You apparently have fuel in the cylinders, and spark at the plugs. If she won't run then they may not be arriving there at the correct times.
Hth,
Brian
1975 Honda CB400F
1978 Honda CB550K
1979 Honda CBX
1969 BSA Rocket 3
1976 Kawasaki KH400
2008 Kawasaki C14 Concours
andy1976
« Reply #3 on: September 07, 2009, 02:20:12 AM »
When I fixed the oil leak I needed to get to the pucks underneath the cam, as I didn't seal them. I'll have to double check everything's timed up right.
When I took the readings, I didn't have the throttle wide open, I didn't know you had to do this,  ::)  Is this to let air into the engine? I'll test it again tonight.
Andy
Offline pdrides
« Reply #4 on: September 07, 2009, 05:59:14 AM »
Is it possible your off a tooth on the valve timing? I think that may give you a false read on your compression.
Will some tell me where the gosh darn kill switch is!!!
Offline crazypj
  • I'm brill, me
« Reply #5 on: September 07, 2009, 07:21:59 AM »
Valve timing wont give variations on cylinders though, unless a valve got bent
PJ
Offline pdrides
« Reply #6 on: September 07, 2009, 07:52:22 AM »
Yea, your right, good point, the compression for individual cylinders wouldn't change. If the valve timing is off it would throw the carb sync and pretty much everything else off though...right? Kinda make sense, if the cam was removed it's a easy mistake to make.
