Author Topic: primary chain and tensioner  (Read 1903 times)
Offline paddy paul
« on: September 06, 2009, 06:49:43 PM »
where is the best place to get new primary chains and a new tensioner, price and quality that is? what brands are available?   Thanks
Offline mick7504
Re: primary chain and tensioner
« Reply #1 on: September 06, 2009, 09:40:45 PM »
Cyclex or Dynoman. Genuine Honda stuff.
I read somewhere that Classic Cycle City in the US are selling heavy duty primary chains.
Sounded like a good thing.
If I was you
I'd be worried about me.
« Reply #2 on: September 06, 2009, 10:04:01 PM »
ServiceHonda.com   ~20% off msrp genuine Honda parts
Just remember to order 1 for the primary chain and you get 1 set of 2 chains. Don't order 2 unless you want to give me one  ;D
Offline mick7504
« Reply #3 on: September 06, 2009, 11:21:44 PM »
Thanks Jerry
I forgot about that.
If I was you
Offline nippon
    • Classic Cycle City
« Reply #4 on: September 07, 2009, 09:32:37 AM »
Hello,
our Classic Cycle City reinforced heavy duty primary chains for the CR750/CB750 are mainly designed for tuned race engines. In stock engines, you can use them of course, too but in fact you do not have to. The stock primary chains will do the job cheaper (not better). During the race season in Europe 2008 and 2009, we measurred a new stock RK chain in a 99 hp engine after 3 races. We measurred a sag of 71 mm ! Honda suggested to replace the chains when they have reached a sag of 69 mm. This means, after three races you have to split the cases in order to replace the worn
chains to avoid possible engine damages. Our chains (6grams lighter each) solved this and the not well working and expensive Hi-Vo conversion with an automatic crank, too. The HD chains saves the racers time and money.
nippon
« Last Edit: September 07, 2009, 09:37:46 AM by nippon »
Offline paddy paul
« Reply #5 on: September 07, 2009, 10:20:27 AM »
 Thanks all
Offline krusty
« Reply #6 on: November 14, 2009, 03:27:35 PM »
"you have to split the cases in order to replace the worn chains "
Can this be done without dismantling the top end? I would imagine that the timing chain would need slacking off by releasing the camshaft sprocket? I need to replace the chains in my CB750F1 and was looking for a short cut. Top end has already been done, rebore cam chain, tensioner, guides etc. The engine seemed to be in excellent mechanical condition so I didn't delve any deeper. Bike runs and shifts just fine but the primaries are really rattling. BTW carbs have been synched and it's not clutch rattle.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline Spanner 1
« Reply #7 on: November 14, 2009, 08:27:39 PM »
Zero short-cut on replacing the cam chain, unfortunately.....are you sure the tensioner is working?... I think it's (very) possible to overtighten the tensioner bolt to where the bolt-end 'mashes' into the tensioner shaft and leaves a burr mark on the shaft. Next time you slack the bolt to allow the tensioner spring to draw the tensioner shoe in, the shaft wont slide as the bolt mark now jams it in it's tube. 2 bolts take the tensioner off for full operation check....just a thought, and maybe something we all should check on our bikes..!!
Offline krusty
« Reply #8 on: November 14, 2009, 08:57:39 PM »
Short cut search was for primary chain replacement, not cam chain.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline Spanner 1
« Reply #9 on: November 14, 2009, 09:53:55 PM »
Sorry , unclear from your post..top-end can stay not dismantled, cam chain dropped off sprocket SHOULD make enough slack to lift the points end of the crank, with #3 and 4 conrod caps taken off, working the primary chains off to the left...but I haven't done it, so please wait for a poster who has attempted it ..!
Offline krusty
« Reply #10 on: November 15, 2009, 11:22:20 AM »
Many thanks, that's what I was hoping. I'll wait for confirmation.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
