Author Topic: JET SIZING TIPS  (Read 38668 times)
Offline HedNut
  • Underwater Basket Weaving
JET SIZING TIPS
« on: September 09, 2009, 11:47:14 am »
I can't take the credit for these tips...but they sound very handy and on the mark.
Enjoy.....
Jetting Recommendations
by Denny Zander
Here is a simple set of jetting guidelines that have worked for me. For those considering jet changes, this might help select a starting point.
1 jet size for custom 4 into 2 exhaust
2 jet sizes for 4 into 1 exhaust
1 jet size for K&N filter (single inside airbox)
1 jet size for drilling out the bottom of the airbox
2 jet sizes for both single K&N and drilled airbox
2 jet sizes for individual filters
2 jet sizes for no muffler (open header)
1 pilot jet size for every 3 main jet size increase
Add up all the jet size increases and subtract one. (Remember they go in steps of 2.5 for each jet size)
Under a mismatch condition, like individual filters and stock exhaust or 4 into 1 header with stock filter and air box, subtract an additional 1 jet size.
Check plug color often, sync carbs after each jet change, make sure the floats are set correctly, and seriously consider purchasing a Colour Tune. (See "Colortuning Carburetors" in the Maintenance Section).
Make sure your carbs are in perfect working order before making jet changes.
Example from my '79 XS1100 F:
Stock main jets: 137.5
Stock pilot jets: 42.5
2 sizes for 4:1 exhaust (Jardine)
1 size for single K&N
1 size for drilled air box
4 (main sizes) - 1 = 3 or 137.5 + (2.5 * 3) = 145.0
1 (pilot jet size) or 42.5 + (2.5 * 1) = 45.0
With this jet configuration I get 32-38 mpg on the open road, Smooth idle, very strong exceleration from off idle to 80+ mph, and steady pull past 120 mph. My "F" has 65K mile on it, of which I have put 33K with this jet configuration.
I have applied this to the '78-'79 carb set with great success. These guidelines should work for the '80-'81 carbs also. The only part I have not tested is pilot jet changing on the second generation carbs.
Happy Jetting
Offline MOD27
  • 1976 cb750k
Re: JET SIZING TIPS
« Reply #1 on: May 31, 2011, 08:48:01 pm »
So if i have 105's in mains and i put k&N pods on and i have a 4into2 with no baffles I would need 125's?
"Get it straight ride krooked"
Offline hapakev
  • Your Standard
Re: JET SIZING TIPS
« Reply #2 on: June 14, 2011, 12:06:47 pm »
I think 115's, according to the math.  Thats assuming that the "open headers/no baffle" cancels out the 4to2 muffs.
Smoking Jack
1978 CB750F(ish)
Offline gsnickets
Re: JET SIZING TIPS
« Reply #3 on: July 21, 2011, 03:53:51 pm »
I think the stock jets on my 72 500 are 100 correct me if im wrong just what i have found and the idle jets are 40 also correct me if im wrong
i have 4 individual velocity stacks and cut off exhaust they go 2-1 on each side stop right after foot pegs
i can only find jets in like 120 130 140 and 150 from my math i need 110 or smaller and a 42.5
Offline RFogelsong
Re: JET SIZING TIPS
« Reply #4 on: December 07, 2011, 11:27:10 pm »
So something's not working out here, if you have a stock airbox and a open header that would be no change at all?
by my understanding:
+2 for open header
-1 from instructions
-1 for mismatch
=0 jet size change??
-Rob
Hondas past/present:
SOHC1:'74 CB125, '78 XL125
DOHC2:'71 CB450K
SOHC4:'73 350F, '75 400F, '75 550K
DOHC4:'81 900F, '01 1100XX
V4:'85 VF1000R, '86 VF500F, '08 VFR800
Offline lucky
Re: JET SIZING TIPS
« Reply #5 on: January 06, 2012, 11:22:35 am »
Enjoy.....
by Denny Zander
Happy Jetting
Are you talking about mainjets,idlejets or both?
maduncle
Re: JET SIZING TIPS
« Reply #6 on: January 07, 2012, 02:31:26 am »
Righto - I am scouring the web looking for jet size advice.
I have a 1977 CB750F2 wit ha stock engine, running a 4 into 2 into 1 set of pipes finished off with a Lossa Engineering muffler.
I am also running one of Tintop's antipod filters.
The carbs have 115 mains in - but after today's ride and some sound advice I reckon I need to upsize the jets.
Based on the theory posted here - if the stock jets were 105:
 - the 4 into 2 into 1 pipes add 2 jet sizes
 - the antipod probably counts as individual pod filters and add 2 jet sizes
 - and then I subtract one jet size
I should go up three sizes from the 105's which I think makes it 112 (105, 108, 110, 112, 115, 118, 120)
- but the 115's aren't doing the job.
Offline lucky
Re: JET SIZING TIPS
« Reply #7 on: January 07, 2012, 09:01:31 am »
I have the same set up and you need to make sure the accelerator pump and nozzles are all working on those carbs. (stock carbs right?)
If any of them are not working it will never run right.
When the engine is OFF, Gas in the float bowls, and the air filters are OFF, turn the throttle and make sure you can see fuel squirting out of all FOUR brass nozzles in the venturi.
As far as the main jets, usually when they say one step up it does not mean 112 up to a 115. Use #120's or 125's
Usually they are not sold in every increment.
If it coughs or spits when you try to advance the throttle it is LEAN.
Remember 0-1/4 throttle air mixture screw and pilot jet.
0- 3/4 throttle slide needle position. You may need to put a shim under the slide needle. Start with one brass shim=.020. Make sure you file or sand the shim(washer) because it can have burrs on it from being punched out during manufacturing.
Wide open throttle mainjet.
IF you hold it wide open in high gear on the road and it keeps accelerating main is ok.
If you hold it wide open on the road in high gear and it hits a flat spot and will not go faster it needs a bigger mainjet.
Also check your plugs  for condition after mainjet run.
« Last Edit: January 07, 2012, 09:05:01 am by lucky »
Offline lucky
Re: JET SIZING TIPS
« Reply #8 on: January 07, 2012, 09:07:41 am »
+2 for open header
-1 for mismatch
Yes that is right.
Stock air filters and aftermarket exhaust may only need a mixture screw adjustment to keep it from back firing if it is too lean.
Re: JET SIZING TIPS
« Reply #9 on: January 07, 2012, 05:19:53 pm »
+2 for open header
-1 for mismatch
Yes that is right.
{from Cliff} I am also running one of Tintop's antipod filters.
The filter Cliff is using is flows more  than the stock box or pods. Cliff, i have seen plenty of guys run 120's with pipes and filter changes, so i would probably buy the 118's and the 120's{never hurts to have a selection of jets}, but also make sure everything else on the carbs  work properly... ;)
maduncle
Re: JET SIZING TIPS
« Reply #10 on: January 08, 2012, 01:59:42 am »
THanks guys - the bike is going over to Terry's this week - since he has the skills, the tools, the parts and the tenacity to get this fixed. I will be the apprentice and watch and learn (if I can).
I reckon we start with 120's and see what that does.
Offline lucky
Re: JET SIZING TIPS
« Reply #11 on: January 23, 2012, 12:03:47 pm »
Some CB750's in other parts of the world came stock with 150 mainjets.
Many times you can use a wide choice of main jets. Too small of a mainjet is the real problem.
Most of the time you are not riding with Wide open throttle.
Getting the mid range and throttle response is very important.
If you give it a quick blip of the throttle and it stumbles or quits, you have more work to do.
Offline lucky
Re: JET SIZING TIPS
« Reply #12 on: February 20, 2012, 10:53:18 am »
Would you please report back and let us know the final outcome as far as you complete set up?
I am sure it will help others.
maduncle
Re: JET SIZING TIPS
« Reply #13 on: February 20, 2012, 02:01:59 pm »
Not a whole lot to report Lucky -  apart from the fact that the 130 size main jets in the stock carbs with a Tintop filter fitted and 4 into 2 in to 1 headers and a Lossa muffler worked out okay and the bike was running well before I sold it last week.
Offline Cross-over
Re: JET SIZING TIPS
« Reply #14 on: March 16, 2012, 05:30:20 am »
Guys, I've got a question about the main jets. My CB750F1 '76 café is finisht and have driven it yesterday. The mixture is to lean and today I wanne place some new main jets, only I really don't now wat size I've to buy.
Some specs:
- Pod filters
- Custom made 4in4 with megatons
- Original size main and idle/pilot jets
The shop I've called does have some jets in the sizes 120, 130, 140 and 150. What size is likely the best? :)
Offline caferacer750
  • yup it getting there
  • ride it
Re: JET SIZING TIPS
« Reply #15 on: April 06, 2012, 04:42:24 pm »
ok so ive shimmed the needle that help out get but at wide open i get a flat at 6000rpm and my main jets are at 135.5 size with a 4 into 2 exhaust and a bed box intake and im a little lost are the 135.5 bigger and a 120 now i can see the hole in the 135.5 is bigger than the 120  in just not sure
Offline crazypj
  • I'm brill, me
Re: JET SIZING TIPS
« Reply #16 on: April 11, 2012, 09:07:35 am »
That's a really rough and ready guide and it doesn't work with CV carbs.
 You know cylinder capacity, you know max rpm, you know you need about 13:1 air fuel ratio for max power, you work out the minimum fuel flow for the known numbers.
When you have cc/min flow, you find jet calculator to switch Mikuni to Kei-Hin (as Kei-Hin use hole size not flow rate)
 It's still a guess as the intake and exhaust efficiency is going to affect airflow.
Most engines only achieve 100% at a very specific rpm, usually 75~80% is nearer the real airflow but when everything comes together it could be 110~130% of calculated flow
Instead of jet numbers, a percentage increase may be safer and more accurate (or less inaccurate?  ;D)
'Pods' and lightly modified exhaust or long pipes need around 10~12% increase, open pipes and too big a carb can need 25~30%, short open pipes, around 20~25%.
Too short a pipe with pods, 30~50%, plus you will gain a lot of noise without any increase in power (until you hit 16K  ;D)
Offline lucky
Re: JET SIZING TIPS
« Reply #17 on: April 13, 2012, 04:05:32 pm »
Enjoy.....
by Denny Zander
Happy Jetting
And what years are "2nd generation carbs"???
Are you talking about 1977-78?
Offline lucky
Re: JET SIZING TIPS
« Reply #18 on: April 13, 2012, 04:07:48 pm »
Thats why the OP said he did not talk about "2nd generation carbs. The 1977-78's
On those i would use 120 mains and #45 idle jets. I know that works.
Offline lucky
Re: JET SIZING TIPS
« Reply #19 on: April 13, 2012, 04:09:04 pm »
+2 for open header
-1 for mismatch
Should just need a mixture screw adjustment. (Lucky)
Offline lucky
Re: JET SIZING TIPS
« Reply #20 on: April 13, 2012, 04:11:14 pm »
+2 for open header
-1 for mismatch
Yes that is right.
I agree with that.
Offline lucky
Re: JET SIZING TIPS
« Reply #21 on: April 13, 2012, 04:16:53 pm »
You are mostly right but it is 14:1 not 13:1.
But you still have to make changes with actual jet sizes.
I wish everyone would tell the whole story...NOT just mainjet size.
IDLE jet ,MAIN jet and needle position. Mixture screw too if possible.
Offline crazypj
  • I'm brill, me
Re: JET SIZING TIPS
« Reply #22 on: April 13, 2012, 07:10:24 pm »
13:1 for max power, 14.7 is stochiometric ratio if it was possible to get 100% efficiency at all rpm/throttle openings
Engine will often be running at around 16~17:1 at cruising high gear, medium rpm small throttle opening
Idle/pilot jet rarely needs much if any increase as the air filters are not restrictive at low rpm
« Last Edit: April 13, 2012, 07:14:25 pm by crazypj »
  • ride it
Re: JET SIZING TIPS
« Reply #23 on: April 15, 2012, 06:48:18 am »
Ok I've found what's wrong the 135 main jet is to big and the power valve was frozen
Got it freed up and put in the one 20 jet and it's better but not 100 percent And my bike is a 78 cb750 k
Offline Dimitri13
  • 1974 CB550K
Re: JET SIZING TIPS
« Reply #24 on: May 04, 2012, 10:55:24 pm »
Do you add these two together if you've got 4-1 headers with no muffler?
