The SOHC/4 Patch & Pin Set is available at the SOHC/4 Store.
That's not a sync problem. My carbs are perfectly synced, and I have the same problem. I'll let you know if I find out why. Do you have any freeplay in the throttle. I don't, but I have it adjusted all the way, no room to get more.
Your carbs can be perfectly synced and if they were synced too high,slide can't physically go down,resync lowering slides,can check by looking or turning idle screw off of stop.Bill
The only freeplay I can find is in the wheel on the carbs which the cables connect to. It only has play in the counter-rotating direction. I tried to tighten the push cable so that the freeplay slack gets taken up when I release the throttle, but this causes some binding (in the cables I think) and the throttle wont return. Maybe my solution is to keep this tight, but get a stouter return srping and lube my cables. How and with what lube does one lube their cables? I could probably search for that...I'll do that now...
... then what the crap is the point of the B cable??
Quote from: bellcow54 on September 10, 2009, 07:54:00 AMYour carbs can be perfectly synced and if they were synced too high,slide can't physically go down,resync lowering slides,can check by looking or turning idle screw off of stop.BillSpot on, i was trying to say it earlier, but couldn't put it together so concisely.I started with a bench synch with a 1/4 drill bit, and this was too high. i had to lower the slides (a lot) about 2 whole turns to get them down enough to stop this problem.
Quote from: tomsweb1 on September 10, 2009, 04:40:43 PM... then what the crap is the point of the B cable??Cable B is so that if cable A breaks then cable B can bring the throttle back down. Safety feature...
Our problem is our throttles are not achieving neutral position. Why is the question.
I would definately try taking all the tension out of the throttle cables, let it idle with the cables real loose to see if that makes any difference.
