Author Topic: stuck cam chain adjuster  (Read 780 times)
74550pa
« on: September 12, 2009, 09:33:34 PM »
what is the best way to free up the cam tensioner screw on the adjuster? am I going to need a partial teardown.this is on a 74 cb550
Offline OldSchool_IsCool
  • Really feeling like an
Re: stuck cam chain adjuster
« Reply #1 on: September 13, 2009, 11:16:23 AM »
Depends on how it is stuck.  Does the stud not turn?  Does the lock nut not back out?  Are the stud and lock nut fused together?
how much of a teardown do you plan to do?  If you are taking the cylinder block off, then you may want to consider replacing the tensioner completely.  You'll most likely wana replace the blade anyway, and the whole unit is only $50 more.  Honda still sells it.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #2 on: September 13, 2009, 11:10:31 PM »
What makes you think it aint free, i never seen one siezed yet
