Author Topic: Is it possible to helicoil a rocker arm? 82 CB650 SC  (Read 614 times)
Offline jeepster
« on: September 13, 2009, 11:16:40 AM »
I was about to put my valve covers back on when I noticed little flecks of threads in the #$%*ing area under the tappets... The tappet SEEMS to be tight, but I have no way of knowing if it will last. Then I noticed that there were some flecks of metal in the hole in the cylinder head cover where the valve cover bolt goes...I guess I need to take it to a machinist?
Is there any way to avoid stripping threads??!!!!!!!!!!!!
« Last Edit: September 13, 2009, 11:21:05 AM by jeepster »
"An ounce of prevention is worth more if you break it up into nickel bags."
Offline tomkimberly
Re: Is it possible to helicoil a rocker arm? 82 CB650 SC
« Reply #1 on: September 13, 2009, 04:47:00 PM »
Can you pick up the chips with a magnet?
Tom
Offline BVCB650
  • Too Much Thin Air
« Reply #2 on: September 13, 2009, 04:53:49 PM »
Only way I know of is to torque them to specs.
1979 CB650, 25K miles, recently refurbished
Offline jeepster
« Reply #3 on: September 13, 2009, 05:24:24 PM »
That was the first thing I did...I don't remember these threads being all that bad, maybe 1/8 gone or so...There is another stripped hole in the cover...glopped sealant on the outside of the bolt, and hoped it held...(was one of the last bolts to go in...) Maybe I can clean the threads of the valve cover hole... I don't want to take the head cover off again then I will be basically forced to helicoil the rocker arm. It would be nice to helicoil the other two bolts but from the way this rebuild has been going I can pretty much guarantee another stripped thread...discovered when the cover is 75% on.
What's my worst case scenario if I leave the tappet as is, and maybe lose a few tiny bits of metal from the valve cover bolt into the cam area? (it's far from the cam, but right above a valve.)
I was thinking of taking the rocker assembly to a machinist and having new threads made. Maybe a time sert welded in?
