Author Topic: Need Help!! Float Bowl Overflow tubes Broken  (Read 898 times)
sloppydawg123
« on: September 13, 2009, 03:23:38 PM »
I have a 79 cb650 i just picked upm obly 2500 miles on it, and after 28 yrs of storage, needed a good carb cleaning. However I feel some may have previously disturbed the carbs, because one of the float bowl overflow tubes was brittle enough to break when my hand brushed it. And another one is cracked. But since they seemd to be pressed in, how can you get them out? Or repair/epoxy them back in? Can you get replacements? Are they just pressed in or screwed in or anything? Any ideas would be great.
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: Need Help!! Float Bowl Overflow tubes Broken
« Reply #1 on: September 13, 2009, 04:46:13 PM »
The tubes are made of brass and are pressed in. I've seen some guys solder them, but it took some practice. You might find some used float bowls ebay. By the way, welcome to the forum.
............Paul
Offline Frankenkit
  • Industrial Strength
« Reply #2 on: September 13, 2009, 06:58:05 PM »
I've also seen people use electrical heat shrink tubes, just slide it over the tube and heat it so it shrink-wraps your overflow tube. That'd work for your cracked one, but honestly you'd be better off looking for replacement bowls.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline Kframe
  • Life is good!
« Reply #3 on: September 13, 2009, 07:18:49 PM »
Huh, I wonder how well the heat-shrink holds up in a constant bath of gas?
Not saying it doesn't work, just that I don't know how solvent resistant that stuff is.
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline Frankenkit
« Reply #4 on: September 13, 2009, 07:19:30 PM »
I'm not sure, either.  The guy who posted the 'fix' said it worked for over a year. ??? that's all I know. :D
1973 CL350- Lola?
Stuff for sale
Offline Frankenkit
« Reply #5 on: September 13, 2009, 07:21:43 PM »
you're lookin' for PD carbs, not too hard to find.  The float bowls for the PD50s were all mostly the same.  I'm not sure which 750s you share float bowls with, but 79 or 80 cb650 float bowls will work for ya.
1973 CL350- Lola?
Stuff for sale
