Author Topic: Anybody with a CB350K4 can do me a little favor?  (Read 2081 times)
Offline Raul CB750K1
« on: September 14, 2009, 03:11:18 PM »
Long time ago, before my CB350 cam chain snapped, the bike had a terrible front wobble. I already opened a thread about it but couldn fix it
http://forums.sohc4.net/index.php?topic=26574.msg271920#msg271920
Then, the engine broke so I put it aside. Now I'm going to rebuild the engine and, while I'm at it, I must deal with the wobble of death. First I have changed the rear 4.00x18 to the original 3.50x18. I have also made sure that the swingarm has no play and it moves up and down freely.
While I was removing the rear wheel for the tire replacement, it dawned on me that maybe the wheel spacers were swapped. I mean, I put them just as they were when I bought it, but I don't know whether they were in their right places -plenty of ham-fisted things in the bike when I bought it.
There are two spacers, one on the sprocket side, one on the drum side. Both have the same inner diameter, the same outer diameter, but different lenght. Parts manual didn't specify the lenght.
Can anybody of you tell me the lenght of the right side spacer? (drum brake side) You don't even need to remove the wheel, just measure it. There is quite a sensible difference in lenght between the two spacers, so you don't even need calipers for that, the precision of a tape measure is enough to distinguish which ones goes where.
Thanks in advance
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: Anybody with a CB350K4 can do me a little favor?
« Reply #1 on: September 14, 2009, 06:20:07 PM »
      Raul, I sure wish I could help you with this, but I just don't have CB350 (or a CL) around here to check for you. Sorry bout that. :-\
Member # 1969
« Reply #2 on: September 14, 2009, 06:51:12 PM »
G'Day Raul, I can't help either mate, but I just wanted to say G'Day to you, I thought you'd gone for good. I had to laugh when I thought about those tire sizes, my new Triumph Rocket 3 has a 240 rear tire, that's almost 10 inches wide!
Anyway mate, good to see you're still with us, have you tried removing the spacers, reassembling the rear wheel on the bike with no spacers, and aligning the chain by sight, or with the aid of a laser pointer? That should tell you which spacer should go where? Cheers, Terry. ;D
Offline hoodellyhoo
  • CB350F
« Reply #3 on: September 14, 2009, 07:23:28 PM »
Glad to see you're working on that 350 again. You did such a beautiful job on the restoration and I felt to bad when the chain snapped. Got any new pics to post of it?
(sorry I can't help as well)
Offline mark
« Reply #4 on: September 14, 2009, 07:36:03 PM »
no K4 here, just the G.   spacer on the drum side is around 35mm....   about 10mm showing outside the seal on the sprocket side.
F you mark...... F you.
« Reply #5 on: September 15, 2009, 03:45:17 AM »
Thanks everybody for your replies. In reverse order:
Mark, I'll check the spacer tonight. I'm almost positive the back wheel setup is the same in the K and G, but if you could confirm the part number of your spacers I could check with mine whether they are the same or not.
Hoodellyhoo, thanks for the kind words. It was indeed a painstaking restoration. The chain snapped, I learn my lessons -not to cut corners anymore when it comes to engine parts- and after being busy with my other bikes, it is its turn to put it on the road again, this time for good. I have even bought replica exhaust, shiny chrome. It is going to be a concours winner!
No new pics of the bike, the latest I post where just some weeks before the camchain snapped.
Terry, did you really get yourself a RocketIII? Man, that bike is impressive, but I doubt you can drag your knee with it on the twisties -guess there are not many over there- haha. That laser idea is a good one. I seem to recall the back wheel was a little off-center with the fender, but I put the blame on the fender itself having bought it used. Maybe I'm just "selling the bear's fur before hunting it" and the spacers are in the right place after all, but I have a feeling they could be the reason for the wobble. You won't imagine how violent that wobble was, at just 70 mph, and the stem bearings were freshly greased, tight, and the wheel spokes were tight in both wheels. Well, we'll see.
And Bill, thanks for chiming in, I know I could have counted on you had you have a CB -not that the GPZ is a bad bike :-)
« Reply #6 on: September 15, 2009, 09:00:25 AM »
Raul, nice to see you back mate, mail me anytime if i can help!
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #7 on: September 15, 2009, 10:42:29 AM »
Wider spacer goes on the brake side if I remeber correctly.
Offline mark
« Reply #8 on: September 15, 2009, 06:56:48 PM »
sprocket side... 42311-286-000
brake side    ... 42313-286-000
It occurs to me that one indication of swapped spacers would be a shiny(or rusty) stripe where the seal had worn - showing on the brake side.
Offline johnspeck
« Reply #9 on: September 16, 2009, 07:23:37 AM »
72 cb350k4 here...
just checked.  i don't have a metric ruler, but with my tape measure or eyes, it's pretty obvious.
the longer spacer (approx. 1.25") is used on the drum side of the rear wheel, the shorter on the sprocket side.
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
« Reply #10 on: September 16, 2009, 07:55:05 AM »
Hi Raul,
Did you look at this site?
http://www.honda4fun.com/spaccati/spaccati.html
Jona.
Found real friends here !!!
« Reply #11 on: September 16, 2009, 12:09:58 PM »
Just checked with my parts manual and the part numbers are the same. Therefore, I will check tomorrow whether the one at the brake side measures 35 mm or 1.25 inches -that is 31.75 mm-, roughly. They are about one cm (1/3 in) different.
From what all you have said, I guess I'm into a dead road with this, seems that mine are in the right place as the longer one is at the brake side. Obviously, the one on the sprocket side had marks of the oil seal, there was no way I could swap them. My concern was that the previous owned had swapped them, as they both were covered with grease when I bought it.
Who knows, maybe the right tire size and a little loosening of the swingarm bolt will cure the wobble. We'll see when the bike is on the road again....
