Author Topic: really need a turque spec.  (Read 767 times)
Offline kopptl
« on: September 14, 2009, 09:27:01 PM »
need torque for 76 cb750 transmition plate.
Offline honda750k
Re: really need a turque spec.
« Reply #1 on: September 15, 2009, 09:49:05 AM »
what do you mean by transmission plate?   like a clutch plate?
These bikes dont die, they hibernate until the right person wakes them up again.
Offline kopptl
« Reply #2 on: September 15, 2009, 10:27:36 AM »
what do i torque the cover behind the shifter to?
Offline scondon
  • Mmmm......tasty bugs
« Reply #3 on: September 15, 2009, 10:56:33 AM »
I haven't found a torque spec for this plate. I've been tightening the 4 phillips head screws down tight, and then giving each a final rap with an impact driver.
Offline kopptl
« Reply #4 on: September 15, 2009, 01:41:35 PM »
 well i just bought allens so it would be easier to remove and work with. dang i think ill just go till theyre all evenly tight!
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: September 15, 2009, 01:48:00 PM »
Assuming a 750.....
If you're talking about the shifter cover (Honda calls it a Mission Cover), which is the rear left engine side cover, there's no torque spec for those screws specifically so use the generic torque spec for 6mm fasteners, which is something really low like 10 ft lb or so.
I just tighten until they're "tight enough", which is a subjective feel that you learn over time.
If it leaks, too loose.  If you strip the threads, too tight  ;)
mystic_1
- John Augustus Shedd
