Author Topic: speed wobbles  (Read 2930 times)
Offline apostrophe28
speed wobbles
« on: September 15, 2009, 11:27:21 AM »
so i finished my build and went around my block for a spin. so excited until i noticed the front wheel wobbeling just a bit. not feel like having the front wheel go flying so heres the information on the front end....any ideas/fixes?
backround: 77'k
-crashed and bent forks and tripple tree - both replaced
-sat over winter outside
-same tires
-no front fender
-little to no fork oil possibly (refilling 1 or both when i get home)
any help would be fantastic, i wanted to go riding when i get outta work tom morning  :-\
1977 750k
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: speed wobbles
« Reply #1 on: September 15, 2009, 11:31:14 AM »
backround: 77'k
-no front fender
Fix these issues.
No.
Offline BVCB650
  • Too Much Thin Air
Re: speed wobbles
« Reply #2 on: September 15, 2009, 11:39:10 AM »
What year and model of bike do you have? Are you certain you got the front wheel on right? On mine, there is a specfic procedure for tightening down the clamp.
1979 CB650, 25K miles, recently refurbished
Offline scondon
  • Mmmm......tasty bugs
Re: speed wobbles
« Reply #3 on: September 15, 2009, 11:53:57 AM »
If the accident was enough to bend the forks and triple trees, wouldn't it stand to reason that the rim could be bent as well?
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
Re: speed wobbles
« Reply #4 on: September 15, 2009, 12:43:30 PM »
+1
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: speed wobbles
« Reply #5 on: September 15, 2009, 01:37:54 PM »
+2.
Offline mystic_1
  • 1970 CB750K
Re: speed wobbles
« Reply #6 on: September 15, 2009, 01:39:34 PM »
-no front fender
No front fender = no front fender bracket = no bracing between fork lowers = fork flex = speed wobble.
mystic_1
- John Augustus Shedd
Offline 750goes
  • it will live
Re: speed wobbles
« Reply #7 on: September 15, 2009, 02:02:05 PM »
Well,
Flat tire - or low pressure,
Wheel alignment
Bent Headstock
Loose Steering Bearings
Bent Rim
Tyre knackered
Swing arm bushes worn out
This list could get quite long
Plus all the other suggestions so far need investigation.
Offline delay pedal
Re: speed wobbles
« Reply #8 on: September 15, 2009, 02:37:59 PM »
-no front fender
mystic_1
does the fender have that much bracing, seems like you could bend the bracket real easy by hand
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: speed wobbles
« Reply #9 on: September 15, 2009, 02:44:59 PM »
It braces quite a bit.
If you don't want the fender, at least grind off the rivets, remove the fender from the brace, and install the brace.
No.
Offline delay pedal
Re: speed wobbles
« Reply #10 on: September 15, 2009, 03:01:46 PM »
will do
Re: speed wobbles
« Reply #11 on: September 15, 2009, 04:55:38 PM »
the reason i have no front fender is i snapped the bolt into the fork on the caliper side. if i instal it with 3 out of 4 bolts would that be enought to stop the wobbel until i get time to drill/re-tap the hole?
also what size is the allan wrench on the top of my forks?....(i beilive there from a 77f) because they look huge.
1977 750k
Offline BVCB650
  • Too Much Thin Air
Re: speed wobbles
« Reply #12 on: September 15, 2009, 05:05:47 PM »
I USED A 5/8 INCH BOLT HEAD ON SOME VISE GRIPS TO GET MINE OUT. Stupid caplocks.
Re: speed wobbles
« Reply #13 on: September 15, 2009, 06:50:14 PM »
if i only use 3/4 of the bolts on the front fender with that stablize it enough?
1977 750k
Offline mystic_1
  • 1970 CB750K
Re: speed wobbles
« Reply #14 on: September 15, 2009, 06:53:06 PM »
Probably not, have you tried to extract the broken bolt?
mystic_1
Re: speed wobbles
« Reply #15 on: September 15, 2009, 07:24:48 PM »
not yet...what would be the best way? i dont have a very powerful drill but i could drill/tap it. maybe a extractor bit on my manual impact driver?
1977 750k
Offline mystic_1
  • 1970 CB750K
Re: speed wobbles
« Reply #16 on: September 15, 2009, 07:32:00 PM »
Sorta depends on how/why it broke.  Did the head twist off from over-tightening or do you think that the threads jammed up?
I've had a fair amount of luck with square fluted extractors, I dont think the spiral extractors work well at all.  If you use an extractor, make sure to use the largest size you can and use the proper size drill for the pilot hole.
mystic_1
Re: speed wobbles
« Reply #17 on: September 15, 2009, 07:33:32 PM »
best guess is i over tightened the bolt
1977 750k
Offline Zaipai
    • My Home page
Re: speed wobbles
« Reply #18 on: September 15, 2009, 07:40:33 PM »
-no front fender
mystic_1
+1
Its my Avatar..
75 CB550F  |
Offline Spanner 1
Re: speed wobbles
« Reply #19 on: September 15, 2009, 08:25:14 PM »
If this is the same wheel that went through the bent forks/ bent triple tree episode it's got to be bollixed......did you jack-up the front and spin the wheel and look for run-out and flat spot on the rim ??
Word of the day;  'bollixed'
« Last Edit: September 15, 2009, 08:29:34 PM by Spanner 1 »
Re: speed wobbles
« Reply #20 on: September 15, 2009, 08:45:15 PM »
is there a BIG chance the front rim is effed up? the forks were pretty bad and the bottom tripple tre was bent a bit, i would rather not have to add more time to this project by having to source a new front rim (i wanted to go on a trip this sat)
when i get home this morning im going to:
-add fork oil
-inflate the tires
-put on the front fender the best i can
-check for flat spots (the bike sat outside allll winter in the same position)
-get the bike up and spin the front tire to see of it spins straight w out any weight on it
if i can get the front wheel to spin straight w out any weight on it does that mean that its alright? because all of the other issues seem to be in the forks and weight-bearing
1977 750k
Offline Spanner 1
Re: speed wobbles
« Reply #21 on: September 15, 2009, 09:02:52 PM »
Weight on the front wheel would have no effect on whether it's not 'true'......
I would rig a pencil held horizontally against the side of the rim fixed to a coat-hanger , sitting on the floor and bent so to support the pencil just touching the rim...spin wheel slowly..blah, blah you know what I mean, but also see does pencil 'ride' higher or lower on rim ( flat spot )....good luck....
Re: speed wobbles
« Reply #22 on: September 17, 2009, 03:36:56 PM »
after taking a better look at the front rim i suspected it wasn't tru. i ziptied a old measuring caliper to it and watched as the rim pushed the needle back in about 4-5mm on the top. no up or down movement what so ever just side to side. brought it to a shop and the guy said it would take him an hr to do top. he's getting started tomorrow so hopefully with that i'll be able to go for a ride as scheduled sat-afternoon  ;D
still going to add fork oil when i get home tonite...figure ill have plenty of time to work on the forks cause im soaking my carbs for 2hrs
1977 750k
