Author Topic: How to fix this header?  (Read 3887 times)
btripp
« on: December 05, 2005, 05:08:50 PM »
Hi guys,
  I still haven't finished my carbs (too much to do at work!) but while I'm working on them I decided it would be a good idea to solicit advice on the next thing to fix: this rusted out exhaust header.
  Can I replace just one of these things or do I have to do the whole set?  I've got the 4-1 exhaust and the other half of this pipe is still attached to the 4 into 1 collector.  It's probably got about 3 or 4 inches missing.  Incidentally, I have the missing part, at least the pieces it crumbled into in my hand!  The other three don't seem to be rusted at all.  Weird huh?
  So...options?
  Thanks!  -Ben
« Last Edit: September 01, 2007, 06:38:40 PM by Glenn Stauffer »
Re: How to fix this header?
« Reply #1 on: December 05, 2005, 05:43:37 PM »
For the time and efffort involved I'd check ebay etc for a replacement. Is that a 400F?
btripp
« Reply #2 on: December 05, 2005, 06:16:07 PM »
'77 550F.  You mean the whole set?
« Reply #3 on: December 05, 2005, 06:41:52 PM »
If it's one of the detachable pipes you could try just finding the single pipe. Honda may have the pipe if it is one of the detachables. You would probably have more luck on ebay etc trying for the complete header section. Maybe someone on the board has one....run it in the wanted section.
Offline cb(r)
« Reply #4 on: December 06, 2005, 06:16:43 AM »
you can replace just one but I think the time and effort might is not worth it.  although, if you have enough good pipe sticking out of the collector you can cut bend and weld on a new piece of pipe.  this is all depending on the tools you have.
The best idea though, was already stated earlier.  look for a complete good used set.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #5 on: December 06, 2005, 07:11:11 AM »
I guess it comes down to what you want the fnished look to be.
My buddy just picked up a 73 CB750 , and one of the header pipes was rusted to the point I could
push my finger thru it. We just welded a patch over the hole , and then wrapped all the int. pipes with
black header wrap.
Simple fix , and cheap...
If you don't wanna go that route , I would look over the great and mighty Ebay...
« Reply #6 on: December 06, 2005, 10:08:39 AM »
Okay, IF your CB550F has the original type 4 into 1 chromed header, it was considered one part and individual down tubes were not available separately. All down tubes were welded together during manufacture, before the chroming operation.
Can it be repaired?  Yes, but not by conventional part replacement means.  I expect a compentent muffler shop capable of building headers from scratch, can fabricate and replace the single tube.  Then you can find a chrome shop and contract with them to have the header rechromed.
I have never seen the original header rust through.  Muffler yes, header, no.  I also have some rusty headers laying around.  But, none rusted through and destroyed as your picture indicates.
Do you think your header is original Honda type?  When you look at the break can you see evidence that the tube was double walled?  I.E a pipe within a pipe?  This would be much more difficult and costly to repair, as I'm not even sure of the process with which they are created.
Let us know...
Offline Killer Canary
  • Typical Bran Muffin
« Reply #7 on: December 06, 2005, 05:01:14 PM »
Any bending shop I've approached about bending pipes for the Canary told me the same thing: they don't have dies that small since the diameter is smaller than automotive.I'm here in the gap, though.
Ended up buying a header at a wrecker for $150.
Kawi GPz900, H1
btripp
« Reply #8 on: December 06, 2005, 06:04:57 PM »
OK.  I went out tonight and took another look at the busted header.  I don't think it's double walled, but I took another picture so you guys could see it.
I'm starting to think the pipes might not be original.  It has a Kerker muffler on it and I think the PO may have replaced the whole thing.
The guy told me he had put that on and had modified it with part of a radiator - the hot water filled type you have in your house - to get a different sound.
  -Ben
« Last Edit: September 01, 2007, 06:39:58 PM by Glenn Stauffer »
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #9 on: December 06, 2005, 07:06:05 PM »
criminy - your carb threw up in your header!
have you cracked the head open yet? might want to wear goggles when you do...
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
Offline Faust
« Reply #10 on: December 06, 2005, 09:22:30 PM »
Don't mean to hijack this thread, but I have a similar problem. Good mufflers on my 550K and blue or rusty header pipes. Does anyone make a chrome clamp/connector so that I could just cut and splice junkyard header pipes?
Offline cb(r)
« Reply #11 on: December 07, 2005, 06:06:16 AM »
funny stuff lol.   seriously I have as set of what I believe is after market 4-2  that were rusted thru.  just not nearly as bad.  so it is a good assumption that these are not stock.  I am not saying it is impossible to make a piece to fit but there might not be enough good metal inside to weld to.  if it were me I would start looking for a new/ used set.
Offline Lumbee
    • My pics...
« Reply #12 on: December 07, 2005, 01:27:25 PM »
...btripp, I'd weld it up for you if you ship it to me...AND its doable.  You say there is a 3/4 inch section thats missing/rotted out.  If you wanted to give it a try I'm up for it.  New welder, and am anxious for some repair work.  ;D  If you could find a replacment section I think it would be weldable...
"I'm not a welder, but I play one on HondaChopper.com"
« Reply #13 on: December 07, 2005, 04:55:20 PM »
Lumbee, what have you done with The Great"Radigga"?
Kawi GPz900, H1
Offline Lumbee
    • My pics...
« Reply #14 on: December 07, 2005, 05:47:18 PM »
...well, I'm Lumbee over on hondachopper.com, so try'n to get a little continuity go'n...
btripp
« Reply #15 on: December 07, 2005, 07:12:46 PM »
Lumbee,
  I appreciate the offer, but I think it may be a little too far gone!  I meant to say that it was missing a three to four inch section of the pipe.  What's left seems to be in not great shape either, so I think I'll just get rid of the whole thing and get a new set.
  Thanks!  -Ben
« Reply #16 on: December 07, 2005, 07:53:17 PM »
Lumbee,
  Thanks!  -Ben
That's it Ben, I'm a half decent welder with arc, mig and oxy-acetylene equipment, and I can tell you now, that the rest of your header will be paper thin , and you'll only do more damage trying to weld it. Throw it in the trash or save it for spares, but forget fixing it, it's an "EX"-Haust, ha ha! Cheers, Terry. ;D
Offline Quail "Owner of the comfortable k8"
  • Now thats good eaten!!
« Reply #17 on: December 07, 2005, 09:36:44 PM »
Terry are the header pipes off pre-K7 different that the 77-78?  I know the mufflers are different but are the headers?
These wonderful little birds are great flyers, delicious eating, excellent for training your hunting dog, and just fun to shoot,or stuff and keep around the house.  Bobwhites can be put with other types of Quail and have very large penis's.  Quail are very popular with the babes.
« Reply #18 on: December 08, 2005, 03:32:36 AM »
Yes T2, the K0 to K6 had different mounting arrangements to the F/F1, K7/8 and F2/3. The header shape is similar though, but the bottom line is that they won't fit unless you either mod the headers, or your head. (which is do-able...) Cheers, Terry. ;D
btripp
« Reply #19 on: December 08, 2005, 04:00:48 AM »
Ex-Haust!  Ha Ha!   :D
A lot of stuff on this bike is Ex-whatever.  I think I have Ex-Carbs too.  Did you see that post?!
  -Ben
« Reply #20 on: December 08, 2005, 03:39:55 PM »
Ex-Haust!  Ha Ha!   :D
  -Ben
Not yet Ben, I'll check it out! cheers, Terry. ;D
btripp
« Reply #21 on: December 08, 2005, 06:20:51 PM »
After looking at my clymer's I'm pretty sure the pipes aren't stock.  They have a square (two over two) collector before the muffler instead of the in-line four collector in the manual.  Can anyone verify that?  The muffler not stock too (Kerker with removable baffels, or so I'm told) and I think the PO replaced the whole thing at the same time.
It does look like they rusted from the inside, as I've heard can happen with these bikes.
-Ben
« Reply #22 on: December 08, 2005, 08:29:02 PM »
That's it Ben, they're aftermarket pipes for sure. Honda had the ugliest collector, although it probably had better ground clearance, and I've never seen an OEM 4 into 1 rot out like yours did? Cheers, Terry. ;D
btripp
« Reply #23 on: December 09, 2005, 06:32:02 PM »
  Can this thing be converted from a 4-1 into a 2-2 or something else?
  -Ben
« Reply #24 on: December 09, 2005, 07:13:37 PM »
  -Ben
What?  You gonna disable two cylinders or hack the motor in half?   The standard options are:
4 into 4  Stock for a K model
4 into 1  Stock for an F model and aftermarket MFGRs
4 into 2  aftermarket MFGRs  But, usually use the stock head pipes.
Best to pick one of these, I think.
