Author Topic: Single throttle vs. double throttle cable?  (Read 3463 times)
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« on: September 19, 2009, 06:18:29 pm »
I was looking for new throttle and throttle grips on ebay. I noticed that all of the new ones are for throttles with one cable. Do they make custom throttles for dual cables like on my cb550? I am looking to ditch the starter all together and wanted to eliminate that bulky thing on the handlebars.
arttbags
Re: Single throttle vs. double throttle cable?
« Reply #1 on: September 19, 2009, 07:26:29 pm »
motion pro sells a double or use only one
Offline robdrobd
  • Who? Me?
« Reply #2 on: September 19, 2009, 07:31:21 pm »
If you use only one do you just have to manually roll the throttle back instead of it springing back on its own?
Offline Roach Carver
« Reply #3 on: September 19, 2009, 07:44:09 pm »
you just use the pull cable. spring on the carbs return it. The only thing the return cable does is allow you to actualy pull the carbs back to closed position.
Offline honda750k
« Reply #4 on: September 19, 2009, 09:18:22 pm »
I personally regard the two cable setup as very useful.  should your carbs become stuck for whatever weird reason, lik say your cable binds somewhere not allowing the throttle to close, your hand will pull them closed manually.    although on the CB carbs, it seems that return spring is ABSURDLY strong for carburetor purposes.
These bikes dont die, they hibernate until the right person wakes them up again.
Offline lordmoonpie
    • Moonpie
« Reply #5 on: September 20, 2009, 06:17:00 am »
some beautiful billet push pull throttles at www.discovolantemoto.com
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline von_Wanderlust
« Reply #6 on: September 26, 2009, 06:33:09 am »
2.5 kids: 1 x CB500, 1 x CB550, 0.5 x CB550 (all basket cases)
Offline moham
  • .fnord.
« Reply #7 on: September 26, 2009, 07:19:51 am »
That's a really cool site...thanks LMP and Von W....
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
