Author Topic: It's alive!!  (Read 995 times)
Offline rchrdms
  • Honda CL350 Twin '72
    • Richard F Meese
It's alive!!
« on: September 21, 2009, 02:29:22 PM »
Hi,
My CL 350 twin that I have been rebuilding all year finally started last night. It took the whole weekend to get the clutch adjusted,
fix the brake cam, set the timing, etc. At about 9:30PM it started up and wanted to really go. I won't take it out of the driveway
until I can really get it road worthy.
This thing has been taken apart since last Fall, It's good to see the gas tank actually on it and not in a corner of the garage.
Thanks to everyone who helped. I still have to give it a decent road test to check it out.
Offline KB02
Re: It's alive!!
« Reply #1 on: September 22, 2009, 03:27:30 AM »
It's an awesome feeling, isn't it, when they start up for that first time, huh?  ;D ;D ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline azuredesign
  • Knupping pin
Re: It's alive!!
« Reply #2 on: September 22, 2009, 04:11:59 AM »
Congrats, I hope to eventually feel the same way!
P.S. can you remove the top end on the 350's with the engine still in the frame?
Offline adams77
Re: It's alive!!
« Reply #3 on: September 22, 2009, 07:53:09 AM »
Still working on mine,  it was born a cb but it wants to be a cl when it grows up.
Offline rchrdms
    • Richard F Meese
Re: It's alive!!
« Reply #4 on: September 23, 2009, 01:51:16 PM »
I am sorry to say no. I've been in your place before and figured it out. I couldn't get the cam case cover off no matter what. You have to take the engine off the frame.
It's not so bad a chore though. Just make sure you save everything carefully for the re-install.
You can take off the side covers if you need to without removing the engine.
Offline rchrdms
    • Richard F Meese
Re: It's alive!!
« Reply #5 on: September 23, 2009, 01:54:33 PM »
I think the pipes are the only thing you need to change. There is a slight difference in torque values too.
I also had some kind of performance cam with bigger lobes in my bike. Now I have a standard cam from a CB model.
Good luck!
