Author Topic: 750 Rear hub Questions.  (Read 629 times)
« on: September 22, 2009, 08:24:49 PM »
I was looking for the O ring for a 750 K wire wheel, goes on the snout on the sprocket carrier side.
 I took one off a Comstar F wheel, but it had a 1/2 round profile on the o-ring. :o
 Is this part same on F & K model?.. book listed it as 68mm x2.6 mm in the early K book.
 Also the F hub, appear to use the same style cush rubbers as a K.. but there are no tits to hold them in place.. ???.. do they just fall out when you pull off the sprocket?
Offline Johnie
Re: 750 Rear hub Questions.
« Reply #1 on: September 22, 2009, 08:31:30 PM »
If this is the O ring I am thinking on the inside of that rear hub, I was able to get them at Honda. Bought 2 this year.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #2 on: September 23, 2009, 06:53:27 PM »
OK, let me rework question.
 Has anyone seen this 1/2 section O-ring?
 Is the K and F model O-ring, 1 and the same?
 what holds the cush rubbers in on a F or are they just loose?
