Author Topic: o-ring madness....  (Read 1594 times)
Offline hfracing1
o-ring madness....
« on: September 23, 2009, 06:42:04 PM »
so I picked up my carb rebuild kits for my 75 cb400f tonight from the honda dealer and got home and don't know exactly which one is to go where. anyone that could chime in with prior cb400f carb experience would be greatly appreciated. In the pic below the new ones are obviously on the left and the old are on the right.
on the right #1 was removed from the needle jet housing
on the right #2 was removed from the bottom bowl screw
on the right #3 was removed from the main jet
do I have them in the right order?
so this means that there is not an o-ring for my idle mixture screw?
The dealer said that one was definitely for the idle mixture screw then that means that Im missing one...???....????
Offline hfracing1
Re: o-ring madness....
« Reply #1 on: September 23, 2009, 06:44:48 PM »
I also already tried putting the o-rings on the jets as the post above implies but it seems that the main jet and the bowl screw o-rings don't fit as well as the needle jet one does.
I'm more worried about not having or not needing o-rings for the idle mixture screws...there were definitely none in any ports when I was cleaning but then someone else had been in there before...
and the honda part number for the kit is:16010-333-315
« Last Edit: September 23, 2009, 06:46:27 PM by hfracing1 »
Offline 750Caferider
  • Crazed Idiot
  • 78 CB750 SS
« Reply #2 on: September 23, 2009, 07:05:25 PM »
Western Hills Honda might have a Micro Fische exploded diagram.  I used it when I rebuilt the carbs on my 750.  Good luck!
78 CB 750F (Yoshimi)
Just picked up 3 early to mid 70's 750's Hell Yeah!
And a basketcase 70!!!!
Offline hfracing1
« Reply #3 on: September 23, 2009, 07:36:53 PM »
I have a honda manual and the exploded that they have show there is no o-ring for the idle mix screw
Offline motorhead55
« Reply #4 on: September 23, 2009, 08:44:04 PM »
Go to any of the "Online" OE honda parts sources and look up the O rings on the parts fische for your bike. The part number will have the O ring dimensions after it. If you have a caliper, you can measure them. From your picture, It looks like you have matched them up.
1976 Honda 550F bought new in 1978
2006 Yamaha TW200 TrailWay
1967 Triumph 200cc Tiger Cub
2007 Dodge 5.9 Cummins Diesel, 6spd. Stick, 4X4
1955 European Spec VW Bug, 1700cc engine, Porsche 356 "A" brakes
1939 Willys Pickup
2003 Kubota B7400
slapi01
« Reply #5 on: September 24, 2009, 05:04:57 AM »
i didn't remove any orings off the idle mix screws i pull off either set of carbs for my 350f that i just rebuilt. just the screw and a spring is all that came out.. you look like you matched it up right... any other o-rings with the kit
