Author Topic: CB450 PISTON SEARCH  (Read 1503 times)
Offline cb550fcafe
    • KDI Cycles
CB450 PISTON SEARCH
« on: September 24, 2009, 08:31:19 AM »
My 1974 CB450 needed new rings, I got the motor in a box, rings were missing. Well as it turns out, the bore is badly rusted. It was finished honed then left untreated to rust in a shed. So now it needs to be bored. Pistons are either expensive or big. I found a set of pistons 3.0mm over on evilbay but they have weird pin locks. So my question is has anyone used larger bore pistons with plastic pin locks? And can a 450 be bored 3.0mm and use a stock head gasket?
Offline lordmoonpie
    • Moonpie
Re: CB450 PISTON SEARCH
« Reply #1 on: September 25, 2009, 04:35:46 AM »
Bore it out and get some pistons from Mark at M3 - lovely wisecos and don't need anything other than a rebore...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline tbpmusic
« Reply #2 on: September 25, 2009, 07:05:50 AM »
Going to 3mm over will require a special head gasket, usually copper ($$).
It will also eliminate any future possibility of boring, as the cylinder walls will be too thin after that point.
So think about it, you may be painting yourself into a corner, so to speak........
The plastic/nylon (whatever they are) wrist pin "clips" are a non-issue, widely used these days.
If you don't feel good about them, then the wire clips are still available from Honda for cheap.
« Last Edit: September 25, 2009, 07:07:21 AM by tbpmusic »
Bill Lane
Foowee
« Reply #3 on: January 10, 2010, 10:05:17 AM »
I know this is an old post.  I tried to pm the op with this info, but I guess the sight won't let me because I'm new...  here ya go:
http://www.bore-tech.com/HondaPistonsRings.html
http://www.bore-tech.com/index.htm
« Reply #4 on: January 14, 2010, 12:46:53 AM »
January's Classic Bike has an article where a man sez he is having pistons made
