Author Topic: Swollen air filter gasket  (Read 776 times)
Offline david 750f
  • 1976 CB750F
« on: September 25, 2009, 12:31:11 am »
1976 CB750F
Replaced my air filter 200 miles ago and the air filter seperator gasket was perfect. Took the carbs off today.  I noticed that the gasket that seals the air filter seperator to the top air filter housing was so swollen that was it had pushed itself out of its groove.
Any ideas?
The sealing foam on the air filter itself has not been affected.
I don't think that my carbs leak. (have not seen any evidence of leaking fuel). Would fuel or oil swell this rubber gasket?
See part 9 in schematic.
Thx.
« Last Edit: September 25, 2009, 12:37:40 am by david 750F »
1976 CB 750F
rostosky750
Re: Swollen air filter gasket
« Reply #1 on: September 25, 2009, 05:42:52 am »
could it possibly be that the gasket was not seated tideley on rebuild? if it was a bit mis-placed or tightened down a tad to hard could this have caused it to bulge out so to speak? will it sit back in its groove or is it all mis-shapen and distorted? if it is, get a new one, they are cheap enough...and dont go over board on tightening,maybe when fitting you could use a VERY SMALL tack of adhesive in each corner just a little spot to help retain it in positition, my guess is it may have slipped out of place as you tightened the filter housing together......
