Author Topic: setting floats?  (Read 1474 times)
Offline kopptl
setting floats?
« on: September 25, 2009, 10:19:18 am »
i know my floats are supposed to be set at 26mm. how do you set them?? i have read that you should tilt the carbs so that the float just sits on the needle and does not push the needle down?? this true?? i just turned them upside down and set them on my bench. this right?? could this contribute to not getting any gas??
Offline Johnie
Re: setting floats?
« Reply #1 on: September 25, 2009, 10:29:31 am »
Don't just tip them upside down. You want to tip them slightly on their side to where the float tip just touches the tip of the needle valve. Set your 26mm from there.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Re: setting floats?
« Reply #2 on: September 25, 2009, 10:42:44 am »
+1
Offline Gorms
  • Barkeep! Give me a beer and a
Re: setting floats?
« Reply #3 on: September 25, 2009, 11:10:16 am »
At least of my '77, the ends of the needle valves are spring loaded.  Adjust the float height from the point where the tab on the float is just about to compress the spring, not to the point where it just touches the end of the valve.
« Last Edit: September 25, 2009, 11:12:58 am by gorms »
Offline BVCB650
  • Too Much Thin Air
Re: setting floats?
« Reply #4 on: September 25, 2009, 11:24:38 am »
Mine is at 1/2 inch from the gasket surface when the needle just makes contact with it's seat.
1979 CB650, 25K miles, recently refurbished
Offline Johnny5
    • CB350F build thread
Re: setting floats?
« Reply #5 on: September 25, 2009, 11:59:10 am »
Just curious why it matters if the carb is upside down or not? If the needle valve is seated, and you adjust the float so it just touches the needle spring pin, then if the carb is on its side, or upside down, wont you still be getting the same reading? Is the needle valve suppose to not be seated when making this adjustment? If so, then I've been doing it wrong.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline BVCB650
  • Too Much Thin Air
Re: setting floats?
« Reply #6 on: September 25, 2009, 12:04:26 pm »
Offline kopptl
Re: setting floats?
« Reply #7 on: September 25, 2009, 12:54:26 pm »
thanks for all the advice!!
Offline Johnie
Re: setting floats?
« Reply #8 on: September 25, 2009, 01:51:47 pm »
Probably because that is the way Honda says to do it in the service manual. At least my KO manual says to do it that way. They must feel the float is to heavy and would depress the needle spring a mm or two allowing the float level to not be set spot on.
Oshkosh, WI  USA
Offline kopptl
Re: setting floats?
« Reply #9 on: September 25, 2009, 01:54:45 pm »
could just turning them upside down and  setting them that way(which i did, wasnt thinking) be part of not tgetting gas?
Offline Johnny5
Re: setting floats?
« Reply #10 on: September 25, 2009, 03:20:49 pm »
Oh okay, I got it right then. As I will sometimes hold the float in place to not depress the needle spring when checking the heights.
1971 CB350
1973 CB350F
Offline w1sa
Re: setting floats?
« Reply #11 on: September 26, 2009, 04:17:40 am »
Yes.
If the method you chose is not applicable to your model's carb float setting procedure, it will (most likely) result in the float/valve  contact point occuring at an earlier point/lower fuel height in the bowl during operation.
If that point is outside the acceptable operating/design parameters, the fuel level will be maintained at a lower level and will not be drawn thru the jets as efficiently.
Normally, more than a mm either way in the setting may deem the setting to be unacceptable for efficient operation/tuning.
