Author Topic: Soak or not to soak.......clutch fibers??  (Read 1236 times)
Offline Joe
« on: September 25, 2009, 03:11:47 PM »
I just got home from work to see an arrival of my new clutch fibers from parts n more  ;D  Dad tells me I should soak em in ATF overnight before installing them, to increase the life/performance of the clutch,  but I'm all out of tranny fluid and I wanna ride today.  This is my first clutch replace, so I figured I'd ask to see if anyone else does or doesn't do this??
I currently have em soaking in some 10 W 40 honda oil, and if I get convinced enough I'm gonna go install em and fire this bike up.
all opinions welcome...your responses can't be any dumber than most of my questions :-[
Offline jreich
Re: Soak or not to soak.......clutch fibers??
« Reply #1 on: September 25, 2009, 03:37:01 PM »
I've only ever used 10-40 or whatever auto oil I've had on hand to soak them and they always have worked great.
Offline Joe
« Reply #2 on: September 25, 2009, 03:59:15 PM »
How long do you usually soak em?
« Reply #3 on: September 25, 2009, 04:32:18 PM »
Dad was right. The pro riders soaked them in ATF overnight or longer. The ATF has antislip properties.
Offline Joe
« Reply #4 on: September 25, 2009, 04:47:35 PM »
I don't usually question the master, but I lack his patience some times.  He knew the valve clearances, and point gaps on my bike by memory, and he hasn't worked on one of em since the 1980's.
Offline bikebitzofvt
« Reply #5 on: September 25, 2009, 06:16:25 PM »
It could depend on the construction of the plates.
EBC and other kevlar plates usually smear with engine oil upon installation.
Cork plates soak in engine oil over night.
I'd like to hear some more about using ATF, never heard that one before...
Tom
"If it ain't broke you aren't riding it hard enough!"
77 CB750K7, 77 KZ1000B
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #6 on: September 27, 2009, 08:33:24 AM »
ATF will increase performance but reduce life of the corks.  The effect is "temporary" i.e a few thousand miles, until the engine oil begins to displace the ATF.  There are two types of ATF; you want type "A", as it is least incompatible with engine oil.  If you like wrenching on the clutch, then ATF is the way to go.  Its less slippery and not as thick as 10W40 when hot.
