Author Topic: Swamp thing sighting  (Read 4141 times)
Offline mrblasty
  • Expertly
« on: September 26, 2009, 02:11:14 PM »
Well I picked up a 1975 Yamaha XS 650.  It's been sitting on the side of dudes house for 8 Alaskan years.  Back wheel is frozen.  But hey it comes with some free 8 year old gas in the tank.  Here are some pics, it's got more moss than an old log.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline Bob Wessner
  • "Carbs Suck!"
Re: Swamp thing sighting
« Reply #1 on: September 26, 2009, 02:46:59 PM »
We know what you will be doing this winter.  ;)
« Reply #2 on: September 26, 2009, 03:14:40 PM »
Shouldered rims should be worth a hundred bux... ;D
Offline Hush
« Reply #3 on: September 26, 2009, 04:29:07 PM »
Hey great project for the winter months mate, as it comes out of the swamp I can even give you a traditional New Zealand Maori name for it.....TANIWHA (pronounced tannyfaa )  ;D means swamp monster. :)
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #4 on: September 26, 2009, 05:15:17 PM »
is the engine frozen?
Mark Twain - Notebook, 1894
Offline mrblasty
  • Expertly
« Reply #5 on: September 26, 2009, 05:49:02 PM »
That's good, at least I'll only be down a hundred if the thing turns into a fire ball.
1973 Honda CB 750
1975 GL 1000
Offline mrblasty
  • Expertly
« Reply #6 on: September 26, 2009, 05:54:20 PM »
I hosed down the cylinders with about half a can of WD 40 and it soaked right through, after I was able to get the kick start lever to rotate, the motor turned fairly easy with the plugs out.  All that really means is the piston rods have snapped off the crank high in the cylinders ;D  Well I'm going back outside to sit on it and make vroom vroom sounds till night time.
1973 Honda CB 750
1975 GL 1000
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: September 26, 2009, 06:16:21 PM »
;D
Offline mrblasty
  • Expertly
« Reply #8 on: September 26, 2009, 07:45:48 PM »
Well the engine turns with some compression with plugs in, and now the rear wheel is free enough to roll around so now I can get it inside.  Once I scoured the moss and lichen off of the engine cases they don't look to bad.  Now to figure out the gas cap, the key I have won't open the latch.
  So I'm thinking about going the hard tail bobber route with this one.  I've been looking around at xs650choppers for inspiration.  After sitting on the 650 the 750 seems really wide.
1973 Honda CB 750
1975 GL 1000
Offline Johnny5
    • CB350F build thread
« Reply #9 on: September 26, 2009, 07:56:34 PM »
That bike would make a cool bobber.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline rachet
  • '77 CB750 F2
« Reply #10 on: September 26, 2009, 09:17:56 PM »
Will you be writing up a build thread here?  I would love to see "Swamp thing" rise again.  This would be a great bobber project.
Rach-
But I need Tacos!  I need them or I will explode!
Offline BeSeeingYou
« Reply #11 on: September 26, 2009, 10:53:33 PM »
Usually I hate to see these old Standards get chopped up but that one is pretty far gone for a restoration.   At least one that makes economic sense.  Parts availability is great for this bike with about the only exception being a master cylinder rebuild kit for the early 650's.  www.mikesxs.net  has after market master cylinders designed to work with that caliper.  I will have to follow this one as I am working on a 75 too though mine will stay close to original.  Good luck.
« Last Edit: September 27, 2009, 12:08:55 AM by srust58 »
Offline mrblasty
  • Expertly
« Reply #12 on: September 27, 2009, 12:13:56 AM »
Usually I hate to see these old Standards get chopped up but that one is pretty far gone for a restoration.   At least one that makes economic sense.  Parts availability is great for this bike with about the only exception being a master cylinder rebuild kit.  www.mikesxs has after market master cylinders designed to work with that caliper.  I will have to follow this one as I am working on a 75 too though mine will stay close to original.  Good luck.
  With the cost of shipping to AK and the lack of availability of these bikes locally I'll be forced to keep things cheap and simple.  I'm shooting for under a grand all told.  I checked out the pics you posted and that's a nice looking bike.
1973 Honda CB 750
1975 GL 1000
Offline BeSeeingYou
« Reply #13 on: September 27, 2009, 12:22:41 AM »
If you have not already check out the XS650 forum at http://xs650temp.proboards29.com/index.cgi
Here are a few 650's I have seen locally this summer.
« Last Edit: September 27, 2009, 12:31:10 AM by srust58 »
Offline mrblasty
  • Expertly
« Reply #14 on: September 27, 2009, 02:47:55 AM »
Nice looking bikes.  I have yet to see one 650 on the road up here, but I have spotted two of the 450's.  I'll check out the site you linked to.
1973 Honda CB 750
1975 GL 1000
Offline DCopp
« Reply #15 on: September 27, 2009, 08:43:20 AM »
by FAR the most chopperized, bobberized, flat trackerized, bike on the PLANET.  You should be able to find TONS of spare parts and inspiration anywhere.   MikesXS.com is the shizzle for parts cheap as hell and great info that you'll no doubt need.
Offline mrblasty
  • Expertly
« Reply #16 on: September 30, 2009, 02:18:48 PM »
Finally got the gas cap open and was happily surprised to find an absolutely rust free and shiny tank.  The petcocks work and the carbs weren't all gummed up either.  After hooking a battery up the lights work ;D  ran out of time other wise I would have checked power through out the harness, that will be this weekends "fun".
1973 Honda CB 750
1975 GL 1000
Offline BeSeeingYou
« Reply #17 on: September 30, 2009, 04:34:05 PM »
That is pretty amazing considering what that bike looks like and where it was sitting.  Just a little FYI on your carbs.  When you take the bowls off you will notice a small brass tube (enrichener tube) sticking down from the left carb body on the forward edge.  The right carb does not have one and this is normal.  This caused me some concern at first as many 650's have one in each.
Offline mrblasty
  • Expertly
« Reply #18 on: September 30, 2009, 06:26:46 PM »
I figured that was what was in place of a choke.  I'm missing the lever but was happy to see that Mikes has them.
1973 Honda CB 750
1975 GL 1000
Offline BeSeeingYou
« Reply #19 on: September 30, 2009, 08:08:33 PM »
The choke activates the left carb and the tube feeds it and then the other carb through a hose connection.
