Author Topic: Locktight on rodbolts?  (Read 1657 times)
Offline johnyvilla
« on: September 26, 2009, 03:44:17 PM »
Do I need to use locktight on my 750 rod bolts? If so will the blue locktight be sufficient?
Thanks.
Offline BVCB650
  • Too Much Thin Air
Re: Locktight on rodbolts?
« Reply #1 on: September 26, 2009, 04:25:19 PM »
I have no idea, other than to say my book called for loctite on the camchain sprocket. I used blue. Can't hurt at all.
1979 CB650, 25K miles, recently refurbished
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: September 26, 2009, 06:00:56 PM »
I've never used loctite there.  I think that means that no manual ever told me to :)
Don't use anything stronger than blue if you want to be able to disassemble them in the future.
mystic_1
- John Augustus Shedd
Offline wrenchmuch
« Reply #3 on: September 26, 2009, 06:04:49 PM »
You don't need locktite on rod bolts but you should consider replacing them . They stretch when torqued and repeated torquing weakens them . There is a thread somewhere about using later f2 bolts . I did this with my re-build and they fit fine . Lube your bolts with oil before torquing.
CB750K1
CB750K4
Offline johnyvilla
« Reply #4 on: September 26, 2009, 07:04:33 PM »
Cool. I have f2 bolts'n'nuts.
Offline BVCB650
  • Too Much Thin Air
« Reply #5 on: September 26, 2009, 07:48:44 PM »
mystic_1
Perhaps a book is on your wish list for Christmas. :-X
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: September 26, 2009, 09:48:32 PM »
mystic_1
I have several, just checked a couple and don't see any reference to using loctite on the rod bolts.
mystic_1
Offline Spanner 1
« Reply #7 on: September 26, 2009, 09:56:08 PM »
Calm down, guys....aren't torque specs. always quoted 'dry' ??
Offline mystic_1
  • 1970 CB750K
« Reply #8 on: September 26, 2009, 09:56:54 PM »
Here's a relevant quote from Hondaman:
The only place I use Loctite on these 750s: on used rod bolts, if they were disassembled. Use  blue, and sparingly. Also: 'feel' those bolts back in, as they take a bit of a curve after years of heat-treating, and should go back in the same way. You'll be able to tell which way is easier...  ::)
Nothing else in the engine needs it, if torqued to the right specs: 90-96 inch-lbs. on the 6mm bolts with 15mm or more threads, 200-210 inch-lbs on the 8mm bolts/nuts.
mystic_1
