Author Topic: Do I need this screw?  (Read 951 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: September 27, 2009, 01:47:59 PM »
OK so I rebuilt my 71 CB750 caliper and replaced the pads. Looking at the ones I'd replaced yesterday I noticed the screw on the pad from the piston side of the caliper. The replacements pads did not have the screw so I overlooked it. What's it for? I'm thinking to keep the pad from rotating but WDIK? Is it essential I open it up and put the screw in?
Offline 750goes
  • it will live
Re: Do I need this screw?
« Reply #1 on: September 27, 2009, 02:25:05 PM »
There should not be any screws in your brake caliper
Offline mycb750k6
  • Rocketman
« Reply #2 on: September 27, 2009, 02:49:27 PM »
This is the screw I'm talking about. It was in the pad when I removed and replaced it.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #3 on: September 27, 2009, 03:16:26 PM »
I would agree, keeps the pad from rotating around.
Offline Peters1983
  • The young upstart of many forum wars
« Reply #4 on: September 27, 2009, 03:18:59 PM »
just take the screw out of the old pads and put it in the new ones. That's what I did.
Chuck dont need oil. Engines run cause they are afraid of chuck! ;D
Offline mycb750k6
  • Rocketman
« Reply #5 on: September 27, 2009, 03:57:56 PM »
Sure I can do that. The question is do I need to? Frankly so far it doesn't appear to be affecting anything.
Offline 750goes
  • it will live
« Reply #6 on: September 27, 2009, 04:09:00 PM »
Never seen a screw in a pad like that before - does it fit into a recess on the piston side ??
Offline mystic_1
  • 1970 CB750K
« Reply #7 on: September 27, 2009, 04:11:45 PM »
Yes.
Personally I'd replace it.
mystic_1
- John Augustus Shedd
Offline mycb750k6
  • Rocketman
« Reply #8 on: September 27, 2009, 04:21:52 PM »
Well this could be another one of those obscure changes made to the early bikes and not documented. The exploded view in the parts manual makes no mention of it. I'll replace it but after just rebuilding the caliper and finally getting rid of my squeal using the dow corning and caliper assembly greese, it's completely quiet now so I hate to have to pull it apart again so that's why the question.
