Author Topic: adjusting valves on cb350 twin...quick question for the experts  (Read 6937 times)
Offline johnspeck
« on: September 28, 2009, 06:18:37 AM »
in my shop manual, it says something to the effect of, "make sure the eccentric indicators are facing out away from the points", where the little "T" mark on the valve adjustment bolt needs to point outwards.
on my left cylinder exhaust valve, the mark is pointing in when i have the clearance properly adjusted.  is this a problem?  i couldn't find anything searching the board.
Offline TimV840
    • YouTube Race Videos
Re: adjusting valves on cb350 twin...quick question for the experts
« Reply #1 on: September 28, 2009, 07:36:46 PM »
I cant help on the original timing marks, since both my 350 twins(race bikes) have the charging system removed and run electronic ignition. But I adjust the valves by turning the engine over and bring each cylinder to top dead center on compression, so both valves are closed, and both rockers have play. Do your adjustment, and move to the other cylinder.
Hope this helps,
Tim
'71 CB350 - Race
'72 CB175 - Pitbike
'75 TR750 Replica - NEW Race
'85 Interceptor 500 - Street
'86 VFR 750 - Street
'96 VFR 840 - Street
'88 FZR400 - 1st Race Bike / Now Street
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #2 on: September 29, 2009, 04:49:09 AM »
Hope this helps,
Tim
DITTO!!
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: September 29, 2009, 05:31:32 AM »
On the 350 twin, the rocker shaft has an eccentric lobe on it where the rocker arm mounts.  That's what modifies the clearance as you turn the shaft.  So, you can achieve correct rocker-to-valve clearance at two positions but one is incorrect to be using.
Loosen the locknut and rotate the shaft in the direction that increases the clearance.  Spin the shaft all the way around until clearance starts reducing again and set the valve clearance.  That should put the index mark in the correct position.
mystic_1
- John Augustus Shedd
Offline johnspeck
« Reply #4 on: September 30, 2009, 04:28:45 AM »
mystic_1
THAT'S what i'm talking about!  thank you for the advice!
on my way home last night, all of a sudden my left cylinder crapped out like it wasn't firing.  maybe a stuck exhaust valve?  i'll look at it today, and readjust.  thank you again!
Offline Green550F
  • Nothing is as cool as that which you made.
« Reply #5 on: September 30, 2009, 05:07:03 AM »
my 350 did that. the carb came loose from the boot!
93 Kawasaki Voyager XII
70 Honda CL350 Cafe
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #6 on: September 30, 2009, 05:23:22 AM »
Wow.  I don't know how I missed that particular.  Gonna have to go back through the valves now and see if I did it right.  She runs but no where near how she should.
Good work paying attention to the details.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
