Author Topic: Road trip to God knows where  (Read 27468 times)
Offline Skonnie Boy
    • What I do for a "living":
« on: September 29, 2009, 07:45:28 AM »
So, today is the day.  After a long summer of rebuilding, replacing and going through my K3/6 with a fine tooth comb, I'm heading out.  From Chicago the first stop is Madison, WI with the second leg being Minneapolis to visit some friends.  If anyone in Minneapolis wants to have a beer with a real live SOHC4-loving loser from Chicago, here's your chance.  I'll hopefully be taking smaller roads out of Madison, eventually finding Route 61 around Lacrosse.  I'll be crashing in Minneapolis for a few days, maybe to catch the Packers-Viking game and then maybe  I'll start heading south in search of Austin, TX.
That's a big maybe.  As much as I've planned and prepared, I really don't know how far my bike will take me.  I'm prepared to fix almost anything, short of an engine rebuild.  But it might end in a U-Haul back to Chicago.  Yesterday, I chanced a white knuckle 10 mile ride back to my garage to fix a fuel line leak that was a near constant stream.  Redid the fuel lines, filters and checked the o-rings on the carbs and got everything airtight again, but need to resynch the carbs before I recheck the valve lash and go.  I adjusted the valve clearances some days ago, but believe I erred on the side of too loose.  #2 and #3 were quite tight, but my adjustment turned a quiet, occasional exhaust pop into a loud crackle.  Assuming this gets sorted out this morning, I should be off.  In true shadetree fashion, I just realized my carb synchronizers are in my garage 10 miles away, meaning I can't resynch the carbs before readjusting the valve clearances on a cold engine.  Might just have to do a bench synch for now and bring the synchronizer up north and do it in Madison.
Assuming I make it Minneapolis (and beyond), I have no set route as far as the southern leg to Austin.  I'll be avoiding interstates as much as possible, and trying to stick to more scenic and interesting routes.  I'll try to post some interesting pics and update as time warrants.  And of course, in the event of some catastrophic breakdown, you can be sure I'll be posting something about that.  And last but not least, if you have advice about routes, bars or feel like having a beer with me, I'm all ears. Regardless, its time to stop procrastinating and hit the road.
Let the good times shake, rattle and hopefully roll.  Bonzai.
Yee and/or Haw.
Re: Road trip to God knows where
« Reply #1 on: September 29, 2009, 08:35:43 AM »
Good luck on your trip!
Some route suggestions  -avoid I-90 in MN and instead take Rt 18 and cross the Mississippi - at the bridge there is a hunting bar and camping site across the road. Will be free when you go ;-). Great beer and friendly former-farmer barman.
Go to the Corn Museum in Mitchell SD - a must see  ;). Dont go to Wall Drug, SD!!! Instead go to Wounded Knee and learn some history. Then take a tour through the Badlands, SD, Needle Pass, SD and stop off and see Mount Rushmore.
Head South and pass through the Ozarks and Little Rock on your way to Austin, TX.
All the best
cheers
Andy
Offline Skonnie Boy
« Reply #2 on: September 29, 2009, 09:57:08 AM »
Thanks.  I might take you up on your Rt. 18 suggestion.  Not sure how west I'll get, though I've always wanted to see the Badlands ever since I saw the movie of the same name.  Always wanted to see the Spam museum as well.
Alright, I'm off.  Mean it this time.
Yee and/or Haw.
Offline Skonnie Boy
« Reply #3 on: September 29, 2009, 09:39:00 PM »
Well, the first update is not really a trip update at all, since I failed to actually leave Cook County.
After adjusting the valve timing and rebuilding the fuel lines, the bike sounded like a lawnmower on the first day of spring and I spent consecutive days traveling down Ogden ave. laying down thick trails of gas.  Having come to the conclusion that my previous valve adjustment had erred on the side of loose, I spent the early part of the day readjusting the valves I could actually access, since most of the covers became completely stripped after a few attempts to open them up.
3 out of 8 valve clearances redone, I proceeded to resynch the carbs by ear, not having the synchronizer nearby.  After achieving 20+ seconds of misfire-free running, I deemed the bike worthy of driving to my girlfriend's garage so I could actually synch the carbs using a synchronizer.  Upon attaching the synchronizer, I found that the readings varied by 10+ lbs./inch, which would explain why the kids I passed made shooting gestures and laughed at me during the ride over.  Bang bang, indeed.
Rebuilding the fuel lines for the 3rd time in as many days, I began to have fantasies of starting my own fuel line supply company.  If I ever do this, I vow to make Carlson Brand Fuel Lines out of something other than recycled food stamp milk jugs, unlike whoever made the brand I  bought from Z1 Enterprises.  Leak free and bundled in zipties, the lines finally holds fuel and after 25 minutes of synching, runs without a hitch or so much as a pop or gurgle.
This being the third day after I said I was going to leave, farewells are growing tired.  My girlfriend is asleep in the living room, having given up on spending any quality time with me before I go.  Its time to quaff the last of this High Life and sleep the sleep of heroes..
Yee and/or Haw.
« Reply #4 on: September 30, 2009, 04:46:13 AM »
I like your style skonnie boy keep it up! I especially liked the part with the little kids making shooting gestures  :D Looking forward to more updates.
Good luck!
Andy
« Reply #5 on: September 30, 2009, 09:40:42 AM »
Too bad you got a bit of a late start..
 Wish You luck on your trip & may the weather Gods smile on You!
 I would head South fairly quick to get into warmer weather. Days are getting short, and it cools off early..
 Anyways... Heres to Plenty of Miles With Plenty of Smiles..  ;D
.. have fun...
Offline Skonnie Boy
« Reply #6 on: September 30, 2009, 09:12:41 PM »
So, ordinarily I wouldn't bore anyone unfortunate enough to click on this thread with daily updates.  But unluckily for you, I'm not engaged in my usual heavy drinking at old hometown bars.  So I have nothing to do but add to the already large amount of poorly written, useless travel journalism as written by self important people who happen to travel somewhere they think is neat or interesting.
Taking off from Chicago, I realize I do not have my registration or proof of insurance, so I destroy whatever punk credibility I had left to drive to my house and put my papers in order.  This takes an extra hour.
Finally on the road at the late hour of 2:30, I decide to forgo scenic routes and just arrive in Madison before sundown.  There's nothing to see in Illinois anyway.  This isn't just my opinion.  Anybody who's travelled 1-90 will tell you that as you pass the "Thank you for using the Illinois State Toll Road" sign, things magically become more interesting and hilly, not coincidentally as soon as you cross the border into Wisconsin.  Its like a Jesus poster, where a single ray of sunshine suddenly pierces the clouds, and shines on you, the person who just left Illinois.
Well, it feels that way to me, a native Wisconsinite.
The bike is running like a champ, not even leaving a drop of oil on the ground when I stop for gas half the time.  There is an interesting splash of oil coming from the oil cap, no doubt due to a bad gasket, but it seems to be fine.  I will hereby jinx myself and say that my carb synch worked like a charm, just a beautiful throaty whine coming from my #$%*ty 4-1 pipes.  There is a different sounding chugging coming from the engine, due to my valve clearance work, but I can't say its bad or off.  And if it is, there's not much I can do about it now.  The bike clearly feels like a bike that has 60+ lbs. of extra luggage and as much extra air to push at 70 mph.  But it doesn't seem to complain, and in return I keep it pretty close to 65-70 mph the whole way, mostly at 4K rpm.
I could go on about phantom noises I hear, the fear of something going wrong, and the omnipresent visions I have of semi drivers falling asleep at the wheel, but who cares.  I'm here, and tomorrow with any luck I'll be pushing through rain and 50º weather up to MPLS.  I picked up a cheap pair of cold weather gloves, so hopefully they'll do the trick.  They look hilariously self important and big, and I'd rather wear my usual gloves with the oddly violent "knuckle protectors".  But I've decided I like having warm hands more than the ability to punch out tail lamps and beat up hapless squares.
Tomorrow I take off west on route 14, to route 60 and then Muscoda to Blue River.  There is apparently a man in Blue River who owns a bike junkyard/museum.  He has imbedded several dozen bikes in the ground a la "Car-henge", as well as affixing all manner and sorts of old helmets to the fence alongside.  Pictures to follow, if all goes well.
Beer.
Yee and/or Haw.
Offline Skonnie Boy
« Reply #7 on: October 02, 2009, 09:51:32 PM »
In the 271 miles of riding over the last 2 days, approximately 30 of those miles were rain-free.  The temperature hasn't broken 53º.  This is the most miserable riding I've ever endured.  My girlfriend's gift of a crappy River Road rainsuit turned out to be the only thing that's made the journey possible.  That, and the long underwear and leathers underneath were the only thing between me and permanent nerve damage to my fingers.  Even with the snowmobiling gloves I bought, I had to stop every 30 miles or so to get feeling back in my hands.  The riding boots I had "fixed" with electrical tape became soaked within 5 minutes, and it was only when I accidentally rested my foot on the brake that I realized I had no feeling in them either.  I had to change socks and wrap my feet in to-go bags to keep them dry and unfrozen.
Still, I did manage to see the bike "art" in Blue River, WI and took a few pics.  It was raining so hard, I snapped 5 pics and had to take off.  Included are some of these rather poor shots.  I made it to Lacrosse in time for nightfall, and decided against continuing in the rain and dark.  To the many half-smiling people who asked where I was going, I would reply, "The Twin Cities", whereupon they would stare at me and simply say "good luck".  The bartender at Yesterdays in Lacrosse looked relieved when I asked her about hotels with covered parking, ending once and for all the debate about whether to continue.
Ended up at some #$%*ty Holiday Inn, but was pleasantly surprised to get into a fascinating conversation about diesel engines with an engineer at the hotel bar over some 7 or 8 beers.  That, and the other guy who offered to tow me to a mechanic or lend me his tools really made me remember why I love the kindness of Midwesterners.  It was only due to the deliciousness of the Pearl St. Downtown Brown Ale that I stayed up past 11pm.   That, and that crappy History Channel "special" on biker gangs on The room TV.
Got up today, snapped some pics of the Heileman Brewery, and shot across the river to Rt. 61.  Breakfast was 2 hardboiled eggs, prepackaged.  It was only when I took the pic that I realized they weren't pickled.  Damnit.  Got about 10 miles in my leathers, before the cold got to be too much.  As much as I hate my black rubber S/M stay-puff rain suit, it really cuts the wind as well.  Of course, when I pulled over to put it on, it started raining.
About 60 miles in, my engine starts knocking under load, in 4th and 5th gear, around 3.5 or 4K rpm.  It could be because my glove slipped, but I felt like I lost power.  It was so cold it was hard to tell.  It freaked me the hell out, and I immediately pulled over at the next gas station.  The sound gets sharper with speed, ending in a ticka-ticka sound at the speeds and rpm described.  I have to think it is somehow due to my valve adjustment fiasco, but its hard to tell.  At city speeds, it sounds OK-ish (though noticeable), pulls fine and the exhaust note is better than its been in a year.  But given my extensive travel plans, I'm not sure what to do.  I could try and source new tappet covers, remove the destroyed ones I have and readjust the valves.  Or I could just soldier on and see what happens.  I've budgeted for a U-Haul ride back home, but I'd rather it not come to that.  Perhaps I should start a new thread about this current predicament.
At any rate, its time to finish this bottle of Aquavit and hit the town.  In a cab, of course.  And as always, if there's any SOHC folk around, pm me.
Rock action.
Yee and/or Haw.
« Reply #8 on: October 02, 2009, 10:29:35 PM »
Man , i love these road reports..
Hang in there buddy, its probably not gonna get much worse right now.. but I would be tempted to make a dash south into warmer weather..
 First night out in late Aug I was near Shelby or Helena  MT around 2:30 or 3 AM.. everybody had warned me about wildlife, I had stopped to eat & rest from about 1 to 2 AM.. and only went 40 miles till I decided to turn in a rest stop.. It was cold.. and getting colder.. :(..
 About 40 seconds after I got my self off the bike a cop rolled in, asked how I was doing & how far I planned on going.. I told him maybe another 40 miles, but it was getting nippy. He again warned me about deer (again) and then told me it was 47 degrees.. :o
 So shortly after he left, I decided to stay there awhile, maybe till first light.. another sh!tty 4 hrs of semi-sleep, alternating between standing up in the washroom and trying to snooze on a concrete bench.. certainly not the first.. or last time... ;)
 But hey, I got from Calgary to 30 miles from Nevada in the first 26 hrs.... first time on a bike in 23 months..
« Last Edit: October 02, 2009, 10:33:49 PM by 754 »
« Reply #9 on: October 03, 2009, 07:48:52 AM »
+1 Great writing and I am laughing all the way through......you are out there doing it, living and making the best of it...I do hope you keep going! Get those new tappet covers - will make your life easier eventually. And I agree about heading South although the weather is going to be variable.
I crossed the Northern route through MN-SD-WY-ID at the same time of year (Oct 2001) and remember the cold wet rain crossing SD and into the Badlands. In the Badlands I made the mistake of stepping off the tarmac onto the Badlands - the soft wet mud clung to my boots and was very hard to get off...big clumps of it. I met 2 other bikers there - and we all laughed at the wet and cold...one guy on a KLR riding to Seattle! And he didnt look too prepared either. He made it though.
Dont forget - Wal Mart is your friend on these kinds of trips - cheap warm clothes (hoodies, sweatshirts) and cheap gloves...and more cheap rain gear if you need it. But heading South at some point will also help.
Keep it coming! This is what adventure is all about - overcoming adversity for those moments of open road bliss in the sunshine  ;)
cheers
Andy
Offline Skonnie Boy
« Reply #10 on: October 04, 2009, 09:24:02 PM »
Ha!  754, you've got me beat as far as road hardships.  I cannot claim anything so punk or tough.  But, the trip has only begun.  There's plenty of time for improbable and terrible things to happen.  I can't wait.
Thanks for the compliment, andy750.  You just wait till I finish the rest of this case of Leinie's and sit down to write a real update.  The MPLS leg of this trip is about to get interesting.  The Vikes/Pack game is tomorrow, and I find myself in the heart of enemy territory, with the most compelling game in recent memory.  If I don't get arrested for urinating on the Metrodome or lose a fistfight with a Vikes fan, I'll count this weekend as an unqualified success.  Huzzah!
Yee and/or Haw.
Offline coldright
  • That's Ms.
  • to you
« Reply #11 on: October 04, 2009, 10:15:28 PM »
Great reading, can't wait to hear how to hear how the game goes... Enjoy the ride and invest in some of those little warm packs to throw in your gloves and boots.  I'm impressed that you're ballsy enough to hit the road that far north this time of year.  I'll snuggle up here on the couch for your adventure stories!
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #12 on: October 04, 2009, 11:00:39 PM »
So, is it interesting yet> ;)
Perhaps now............
 is the time to engage in your usual heavy drinking at new hometown bars ;D
Offline Skonnie Boy
« Reply #13 on: October 05, 2009, 12:09:41 PM »
"Interesting" is one way to describe the Twin Cities right now.  Its hard to overstate the frenzied fever pitch that the Monday Night Game is generating.  While some Vikings fans seem to have the correct antipathy towards Mr. Favre, most seem to have jettisoned any sort of reservations about the affair.  Its as if there's been a collective moral loophole created to neatly dispose of the troublesome issues the QB switch brings up.  The Vikings fans just seem content to buy newly minted #4 jerseys and other purple swag while enjoying their improbable 3-0 start.  Truthfully, not much else is to be expected from such a young franchise without the benefit of a long history to guide them in matters of ethics and pride.  This will be the crux of what I'll be drunkenly yelling later this evening.
After getting lost twice in the city, I arrive on the MPLS doorstep of my friend Watkins.  In addition to being one the finest traveling companions you could have, Watkins is also one hell of a host.  His encyclopedic knowledge of architecture, city history and heroic alcohol tolerance make him an invaluable partner in the search for good times and cheap thrills.  As soon as I pull up, he's got a tallboy in my hand and is helping me dismantle my luggage.  I'm a stuttering mess, and 5 different stories are trying to come out of my mouth at once.  After a few beers, I calm down, and we attend to the task at hand of getting drunk and catching up.
First on the itinerary is a visit (by bus, BTW) to Palmer's, a delightful #$%*hole of a place that seems to cater to collegiate punks and uppity homeless people.  It has a nice Grain Belt sign in front, as well some nice floor tile mosaics of the same brand logo.  It likely was a tied house, meaning that long ago a brewery fronted the bar money for construction in exchange for serving only that brewery's beer.  A three piece band is playing on a stage that measures 8' x 6', and within 5 minutes we see someone get 86'd for trying to start a fight.  An older woman starts chatting with us, and pretty soon Watkins and her bond over stories about blizzards they've been through.
Apparently, drinking somewhere that legally serves alcohol is too classy for us, so the next stop is a BYOB art space where a bunch of bands are playing.  Everybody here is easily 10+ years my junior, but everybody's drinking from cases of beer they brought in their messenger bags, and they're all pretty friendly sorts.  The bands are a nice departure from 3rd generation punk rock, and there's even a band composed of godless longhairs trying to channel Roger McGuinn.  Nice.  I look around and get vague feelings of deja vu from basement shows I used to go to some 15+ years ago.  But the energy is good, and in what must be an example of cultural evolution, they hardly wear any spikes or leather.  And they all ride cruddy looking fixies, so good on them.  Nice kids.  I get whasted, and all is more or less right with the world.
The next day we head out to what Watkins describes as a "Boo-Ya Festival".  "Boo-Ya" is apparently a type of soup that is made in 55 gallon drums with ox tail and other types of meat.  Having previously thought Boo-Ya was a feeling or intangible sentiment or sorts, I am thrilled to be able to capture Boo-Ya on film as well as consume it.  What a country.  Also, I consume some fine Polskas and deep fried cheese curds, though I feel somehow like I'm cheating on my native cuisine by eating it in Minnesota.  Weird, I know.
Its time to figure out what the #$%* is going on with my bike, and after a somewhat panicked post about finding new tappet covers, forum member srust58 contacts me and gives me a great tip about a bike junkyard in Jordan.  He graciously offers to drive me there, even.  I reassure him bike is not that badly off, but I do take him up on his offer to check my bike out and troubleshoot.  Watkins and I ride out to his place, and soon we are chatting about sailboats, road trips and English bikes.  srust58 is the owner of an immaculate '76 750F, which is 99% stock.  It even has factory yellow dabs of paint on many of the bolts!  We get to discussing what's wrong with my bike, and srust58 suggests that, in fact, nothing is wrong.  He's probably right.  My bike ran like #$%* because I was running open pods through 240 miles of rain.  The knocking sound is well within the "sewing machine" chugging of a normally running engine.  In truth, srust58 has effectively talked me off the ledge.  His invaluable advice has made my day.  So, here's to you srust58, a fine example of kinship among riders.
Its about time to take off and take care of some #$%*.  After three days, my boots are finally dry again and in need of some new insoles.  The weather isn't getting any warmer, so some of those hand warmers are also in order.  If I'm going to have pleasant weather and riding, I'm going to have to switch states.  Wednesday I take off, hopefully in the direction of Austin, TX.  Not sure of the route I'll take, but the idea of heading west isn't a good idea at this point of the year.  Oh well.
Time to get more beer and find a bar for tonight's game.  If all goes well, there'll be a steady stream of purple and yellow heading to the locker room on stretchers tonight.  Kill, Pack, kill.
Yee and/or Haw.
Offline Skonnie Boy
« Reply #14 on: October 06, 2009, 09:56:47 AM »
Its a good thing it does nothing but rain in this town because I wouldn't piss on it if it was on fire.  Steady, constant 50º rain.  FTW.
Anyway, I'm outta here tomorrow.  Here's some pics.
-Weird antique shop by Watkin's apartment.
-Eating Minnesotan meat.
-My basic setup.  Note the army surplus bag with heavy bungee action.  $17 tankbag from newenough.com.  Saddle bags patched with duct tape with "custom" rat bait stencil.
Yee and/or Haw.
Offline j squared
  • www.iliketogofast.com
    • ILikeToGoFast
« Reply #15 on: October 06, 2009, 12:01:20 PM »
Very entertaining so far, although I gotta say even at 55 degrees here in Atlanta Im driving with the heater on.  I wonder if you could fit a space heater on that cycle :)
If you happen to find your way to Georgia let me know, I have a bed and beer or three with your name on it.
Offline Skonnie Boy
« Reply #16 on: October 06, 2009, 01:05:04 PM »
Ha, yeah I've thought about a space heater.  But I think I'm just going to go with a basic gas-soaked rag stuck in the tank.  It'll be sort of like traveling with my own personal eternal flame.
Many thanks, j squared.  If I do end up heading that way, I'll let you know.  I lived in Atlanta from '01 to '03.  I still dream of yacht dogs from the Euclid Ave. Yacht Club.  Soul satisfying stuff, that.
Yee and/or Haw.
Offline alltherightpills
« Reply #17 on: October 06, 2009, 06:28:22 PM »
If you feel like getting into a fight with some frat boys in Iowa City, let me know.  It's homecoming this weekend, so you might be able to get into a fight with their parents too.
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
Offline Skonnie Boy
« Reply #18 on: October 06, 2009, 07:16:01 PM »
I'm taking two days to get down to KC, and I hadn't mapped out a definite route.  I'm leaving tomorrow, so its short notice.  Also, I'm a bit above my fighting weight.  But if you feel like having a beer with a genuine Chicago sohc4 loser, let me know.  Hotels booked up in I.C?
Yee and/or Haw.
« Reply #19 on: October 06, 2009, 08:11:28 PM »
PM sent.
78 550K
77 550K (in pieces)
« Reply #20 on: October 06, 2009, 11:06:42 PM »
Ride on out to Colorado. We're getting some on again off again solid rain alternating with 80's and sunshine. Either way you'd stay drier. Might freeze the boys off though.
Offline Skonnie Boy
« Reply #21 on: October 07, 2009, 06:26:00 AM »
That's really tempting, but I've heard Iowa is lovely this time of year.
In all seriousness, had I started off a bit earlier in the summer I would have liked to get further west.  My original plan/dream was to visit the areas where "Pee Wee's Big Adventure" were filmed.  Oh well.
So now, having filled Watkin's house with stale smoke and beercans, its time to head off and pollute somebody else's life.  For the first time in 5 days, the sun is shining.  It is also 38º degrees out.  I've bought handwarmers, both for feet and hands, and I'll soon find if they work, as well as if my bike will actually start.  I've had ziplocks covering the pods, so hopefully its kept the rain out and not trapped too much moisture.  That poor bike.  For all the attention I've given it over the last two and half years, I'm beating it like a redheaded step mule rented child.
Anyway, here's the sendoff.  Its the official theme song of this tour.  Its sums it all up nicely.  Plus, no one has written a song about a rusty machine with year old black primer.  Adios.
[youtube=425,350]<object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
Yee and/or Haw.
Offline Big Bob
« Reply #22 on: October 07, 2009, 09:33:32 AM »
You should've come by.  I've got piles of tappet covers.
I'm leaving for the Barber Vintage Festival after work today and this story is making me jealous.
Offline Skonnie Boy
« Reply #23 on: October 07, 2009, 10:51:58 PM »
If it makes you feel any better, its supposed to rain the entire day tomorrow.  Time to don the S/M stay puff rain suit.  Might as well just wrap it around the pods for all the good it'll do me tomorrow.
Barber vintage festival?  Speaking of jealous.
Yee and/or Haw.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #24 on: October 07, 2009, 11:49:16 PM »
Well here's my $25.00 rain suit, It's done 2 road trips ;D ;D ;D
Lets see yours ;)
