Author Topic: Chain binding? Clicking?  (Read 1289 times)
Offline schwebel
« on: September 29, 2009, 06:41:44 PM »
The chain on my 350f is making a weird binding/clicking sound. It made it when backing up at first, now it makes it going foward after I adjusted the slack. It sounds like it is coming from the rear sprocket area. the rear tire will not spin evenly, when it clicks it slows it down. The rear sprocket is brand new, as is the front. I do have a CB450 rim on the back with a larger tire than stock, but have run this setup for about 1500 miles with no issue.
Online Don R
Re: Chain binding? Clicking?
« Reply #1 on: September 29, 2009, 07:26:59 PM »
Rusty or stuck chain links?
« Reply #2 on: September 29, 2009, 07:29:59 PM »
Did you put a new chain on also with the new? sprockets ?
Offline moham
  • .fnord.
« Reply #3 on: September 29, 2009, 07:38:08 PM »
Sounds too tight...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline BVCB650
  • Too Much Thin Air
« Reply #4 on: September 29, 2009, 08:19:51 PM »
Stiff link or two or three. You can try to lube it and free it up, but a good practise is to replace the chain with the sprockets.
1979 CB650, 25K miles, recently refurbished
Offline Honda?
  • Made in the Midwest
  • BEER!
« Reply #5 on: September 29, 2009, 10:18:55 PM »
If the sprockets are new and the chain is old and there are no binding or stiff links your chain could be stretched out enough for it to not fit in the sprocket teeth evenly.
My money is on a stretched chain.
I have a 1970 CB350 SS, 1988 NT650(Hawk GT), 2004 BMW R1100S
Offline Operator
  • Someday I will live up to being a
« Reply #6 on: September 30, 2009, 11:49:36 AM »
I agree it sounds like a stretched chain, at the same time, I used to run dirt roads a lot and sometimes you wil get some sand and grit in between the chain and the sprocket grooves that you can't see unless you loosen the chain off and lift it off of the sprocket.
If ever there was a creator of bastard sons, it is the open road, for she has claimed so many young men yearning for freedom......
1973 CB750 K3
1976 CB400F (Cafe Project)
1979 Yamaha XS400 (Currently up for Sale)
Offline IHWillys
« Reply #7 on: September 30, 2009, 01:37:49 PM »
Also check for other things like a bolt on the sprocket backing out and just touching something.  I had this happen on an XS650.  It would click only on acceleration, when the cush drive would flex enough to have the bolt head just barely touch on something back there(I don't recall).  PO had installed new chain and sprockets and installed three of the four rear sprocket bolts correctly.  My mistake for not checking it out more thoroughly...
Ken
