Author Topic: Need help finding CB350f cylinders...  (Read 2491 times)
cb350f_dave
« on: September 30, 2009, 03:02:16 pm »
I'm having a rough time finding usable cylinders for my
CB350f. The existing cylinders need to be bored, therefore meaning
that I need to get .50 pistons. Since I cannot find .50 pistons
I need to find a stock cylinder head so that I can put standard
pistons in it. I have found a 75 CB400f head but not sure if it
will fit?
Any suggestions?  :-\
« Last Edit: September 30, 2009, 03:29:53 pm by cb350f_dave »
Offline BVCB650
  • Too Much Thin Air
Re: Need help finding CB350f cylinder head...
« Reply #1 on: September 30, 2009, 03:10:27 pm »
I'm confused. Valves go in heads. Can you have it bored to whatever size you can find pistons for instead of .50 over?
1979 CB650, 25K miles, recently refurbished
cb350f_dave
« Reply #2 on: September 30, 2009, 03:28:41 pm »
Sorry, my mistake...I meant that I need cylinders. I can have it bored but the problem is that I can't find any pistons, except for standard, and we know they won't work if it is bored.
Thanks
« Last Edit: September 30, 2009, 03:30:37 pm by cb350f_dave »
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: Need help finding CB350f cylinders...
« Reply #3 on: September 30, 2009, 03:32:21 pm »
Could go 4mm bigger and install 400f pistons :)
No.
Offline crazypj
  • I'm brill, me
« Reply #4 on: September 30, 2009, 03:32:37 pm »
Bore it for CB400f pistons.
PJ
cb350f_dave
« Reply #5 on: September 30, 2009, 03:35:14 pm »
author=crazypj link=topic=59309.msg643002#msg643002 date=1254349957]
Are those pistons available? I would definitely do that
if I can find those pistons.
Thanks
« Last Edit: September 30, 2009, 04:00:19 pm by cb350f_dave »
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #6 on: September 30, 2009, 03:54:12 pm »
Looks like bikebandit may have them, brand new.
7: PISTON (STD) (STD) 3835990-001  $47.93
No.
cb350f_dave
« Reply #7 on: September 30, 2009, 03:59:52 pm »
Thanks...I will do that. Just want to make sure that I will not
need to change anything else though right?...(connecting rods, etc)
« Last Edit: September 30, 2009, 04:09:02 pm by cb350f_dave »
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #8 on: September 30, 2009, 04:20:07 pm »
Far as I know, things should hook up just fine. You are going to want to check for sleeve thickness, though. Dunno how thick the sleeves are on the 350, and that's a pretty sizable overbore.
They also had a couple sizes up listed....
400 head is better than 350 head too, and it may be an easy swap. Something to look at... then, hey, you could drop in the 400 6 speed tranny :)
No.
Offline Trevor from Warragul
« Reply #9 on: October 01, 2009, 12:28:25 am »
The answer to your problems!
http://www.cmsnl.com/products/piston-050-repro_06133333000p/
You little ripper!
Trevor
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Offline crazypj
  • I'm brill, me
« Reply #10 on: October 01, 2009, 03:35:28 pm »
cool link, I've got a CB400f block that needs a clean up bore (and a CB350 one in same condition)
PJ
cb350f_dave
« Reply #11 on: October 01, 2009, 04:21:40 pm »
So will a 400 head fit on a 350? According to the parts
list they are different numbers?
« Last Edit: October 01, 2009, 04:24:27 pm by cb350f_dave »
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #12 on: October 01, 2009, 04:28:38 pm »
They are different. I think fitment is not difficult, though. The 400 head breathes better, from what I understand.
No.
cb350f_dave
« Reply #13 on: October 01, 2009, 04:32:06 pm »
Thanks mlinder, so will it bolt right on, because I have access to a 400 head if it does?
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #14 on: October 01, 2009, 04:33:55 pm »
There's something different that needs to be done. I can't remember what.
Take a look at both of em and see whats different.
No.
cb350f_dave
« Reply #15 on: October 01, 2009, 04:35:30 pm »
I would but I don't have the other one...I have to buy it first.
Thanks for your help though.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #16 on: October 01, 2009, 04:38:01 pm »
Again, I think it's very minor.
No.
cb350f_dave
« Reply #17 on: October 01, 2009, 04:39:36 pm »
ok...thank you
Offline camelman
  • Man... Myth... Legend
« Reply #18 on: October 02, 2009, 11:28:27 am »
Two or four of the studs are different lengths for the 350 and the 400.  They are in the same locations, but are definitely different lengths.  You will need to pull them from the 400 block if you are going to install the head.  I'm not sure if there is a difference between the cylinders.  The 350 also has a bolt or two that you won't use.
I would suggest just putting in a 400f complete engine instead of mixing and matching.  That, or going with bigger pistons.  I bought a set of the pistons (link shown in a previous post) from CMC (?) and they fit nicely.  The machine shop I took the cylinders to was impressed with them too because they were made to tight tolerances.  The only issue you will have is finding a shop that will bore and hone such small cylinders.  If/when you find them, make sure they verify the pistons fit in the new holes.
I have a set of 0.75 over pistons/rings/clips if you want them.  All told I paid $300 shipped for them.  I'll let them go for $200.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
